x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
04-21-2003, 02:03 | #1 (permalink) |
Junior Member Join Date: Apr 2003
Member: 26954 Status: Offline Thanks Meter: 0 | Can i flash my me45 with original data cable (which comes in mobile pack) Can i flash my me45 with original data cable ? (which comes in mobile pack) If i can't , how can i get/make data cable for flashing. and how can find turkish version of me/s45i bin file or how can i install turkish language after flashing to i. and which is the easy and recommended upgrading for 45to45i because i found more thane one flashes and methods. and i am a starter , rookie i have a lot of questions and i need a lot of answers ; sorry for that! |
04-21-2003, 13:17 | #2 (permalink) |
No Life Poster Join Date: Sep 2002 Location: EEPROM damaged Age: 44
Member: 15315 Status: Offline Thanks Meter: 1 | yes you can: put 3..5V between two pins of the data cable connector (on mobile site) Pin 1 (black) --> minus Pin 4 (white) --> plus easy way is WinSwup S45i v4 and the S45i Activator (www.gsm-dev.com) |
04-21-2003, 21:42 | #3 (permalink) |
Junior Member Join Date: Apr 2003 Location: Romania Age: 43
Member: 27009 Status: Offline Thanks Meter: 0 | I don't understand...What u mean by " 3..5 V " ? All i have to do is to put some voltage in the cable ? (something beetwin 3v and 5 v?) . And i have to do this by conecting pin 1 and pin 4 ? Can i use then a flash-light battery ? thanks. |
04-21-2003, 22:36 | #5 (permalink) |
Member: 27009 Status: Offline Thanks Meter: 0 | By "flash-light baterry" i ment 2 AA size battery... (1,5 v x 2 =3 V) Another thing......those 2 wires have to be connected at the cable all the time, is that wright ? And.... i have a problem with "S451Activator" . I get this error " "Failed to load control 'gsmdev' from . Your version of may be outdated. Make sure you are using the version of the control that was provided with your aplication. " This is the EXACt message. I don't know from WHERE it can't load the control. can you help me ? The error ocurs because i use the original cable ? Thnaks again |
04-24-2003, 20:12 | #8 (permalink) |
Junior Member Join Date: Mar 2003
Member: 24702 Status: Offline Thanks Meter: 0 | http://www.ccitt5.net/mtn/temp/image{001-011}.jpg That is, from image001.jpg up to and including image011.jpg Or download them as a .tar.gz archive: http://www.ccitt5.net/mtn/temp/images.tar.gz These images are from a tutorial written in spanish about how to create the cable you need.. The tutorial in question can be found under "GSM-Forum" / "Tutorials" but unfortunately is in Spanish.. Its a very simple procedure to create this cable though! You can translate the tutorial with babelfish and it'll actually make some sense too. Good luck with the cable! |
04-24-2003, 21:55 | #9 (permalink) | |
Junior Member Join Date: Jun 2000 Location: Spain
Member: 1640 Status: Offline Thanks Meter: 0 | Quote:
http://forum.gsmhosting.com/vbb/show...threadid=76064 or visited http://groups.yahoo.com/group/TranS45/ files | |
Pls. how can I unlock my K300i using USB data cable? | miracall | Sony Ericsson Hardware Repair | 0 | 12-27-2006 17:16 |
Can I Flash Sgh e720 with Original Usb Cable? | seedo | Trident/AGERE Platform | 0 | 09-26-2005 14:15 |
Unlock java with original data cable?? | Sinister-BR | Siemens Hardware Repair Area | 0 | 10-11-2003 05:43 |
How to unlock ME45 with orig. data cable??? | Tato | x1x to x45/x50 | 3 | 07-01-2003 21:24 |
s45 unlock with original data cable or without cable | rakadjiev | x1x to x45/x50 | 2 | 05-21-2003 20:58 |
