dead c35 Erm i have a c35i and i think i have ****n something on it. I put a higher voltage to the + & - battery connectors (about 9 volts not reaslizing it was so high). Now it wont turn on or flash or anything. Anyone know what ive ****n and if it can be sorted? |
noone have any ideas then? |
Get circuit the diagram, test the line, then test voltage out put of the Power IC. If IC is not Ok change it. best luck. |
Yes I think it is the last solution for your Phone!!!!!! |
You can as well check properly if there is burnt component, becos we repear r220 pluged into 220v ac which only cause some component to be damaged. |
C35 siemens dead, can any body help Pls i have c35 dead, and i check all the necessary connector but foud intact pls what you i di nextthanks in advavce |
