Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 12-17-2003, 18:47   #1 (permalink)
Member: 46716
Red face dead c35
Erm i have a c35i and i think i have ****n something on it. I put a higher voltage to the + & - battery connectors (about 9 volts not reaslizing it was so high).
Now it wont turn on or flash or anything. Anyone know what ive ****n and if it can be sorted?
Old 12-22-2003, 15:09   #2 (permalink)
Member: 46716
noone have any ideas then?
Old 01-03-2004, 16:32   #3 (permalink)
Member: 45410
Get circuit the diagram, test the line, then test voltage out put of the Power IC.
If IC is not Ok change it.
best luck.
Old 01-19-2004, 12:24   #4 (permalink)
hakima's Avatar
Member: 33804
Thanks Meter: 22
Yes I think it is the last solution for your Phone!!!!!!
Old 06-24-2004, 18:38   #5 (permalink)
Member: 67558
You can as well check properly if there is burnt component, becos we repear r220 pluged into 220v ac which only cause some component to be damaged.
Old 06-24-2004, 18:46   #6 (permalink)
Member: 67558
Arrow C35 siemens dead, can any body help
Pls i have c35 dead, and i check all the necessary connector but foud intact pls what you i di nextthanks in advavce
Steel dead c35 Roman x1x to x45/x50 4 07-27-2001 02:06
Dead C35 TITO x1x to x45/x50 4 07-23-2001 14:20
dead C35 by Martech v 1.7 sedlin x1x to x45/x50 3 06-05-2001 22:23
totally dead c35 frankn x1x to x45/x50 14 03-31-2001 10:41
DEAD c35 phones ... makona x1x to x45/x50 1 03-22-2001 11:39
Page generated in 0.20602 seconds with 9 queries
