x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
07-24-2002, 19:28 | #1 (permalink) |
Junior Member Join Date: Jan 2002 Location: RUSSIA Age: 46
Member: 9048 Status: Offline Thanks Meter: 0 | Flash HC: 9020 How to fix it? Now all prog's show FlashHC: E6FF - instead of 9020 STM 28W160BT Top 16 MBit For example: Swup194.exe ---------------------------------------- sending update-software .. unknown flash: ID: E6FF (AMD-Alg) or E6FF (Intel-Alg) this Flash is not supported ! ---------------------------------------- How to reflash or erase it properly? |
07-25-2002, 02:06 | #2 (permalink) |
Freak Poster Join Date: Feb 2002 Location: Russia
Member: 9418 Status: Offline Thanks Meter: 15 | Sorry for non English message! ====================== А каие у тебя проблемы с 9020? Этот флэш всегда прекрасно понимался Ziemens'ом, и тем более всем, что посвежее? Если чем смогу помочь - пиши на мыло, а то по буржуйски уже надоело разговаривать... |
07-25-2002, 07:59 | #3 (permalink) |
Freak Poster Join Date: Oct 2001 Location: [internet]
Member: 6877 Status: Offline Thanks Meter: 0 | Possible hardware failure? %subj?? E-mail has been sent with a couple possible tricks to fool Flash-ID and try to erase this flash anyway.But it looks like hardware problem.Flash Type=9020 is about to be "well known" and "not a problem" flash type... |
07-28-2002, 17:18 | #4 (permalink) |
Freak Poster Join Date: Feb 2002 Location: Jakarta
Member: 9261 Status: Offline Thanks Meter: 0 | using full flash x35 dead is very easy problem solution 1: - Flash with All 34 Service Software crack by XaX - Use .flx file for flash it (you can find this file in forum) - for repair blank display use workshop 1.22 by pro & CEE REPAIR - change your IMEI by Lead software solution 2: - Full flash with winswup ver 18 - Use Logers Up & LC files (contact me) - for repair blank display use workshop 1.22 by pro & CEE REPAIR - change your IMEI by Lead software |
07-31-2002, 07:17 | #5 (permalink) | |
Junior Member Join Date: Dec 2001 Location: Hungary
Member: 8130 Status: Offline Thanks Meter: 0 | Re: Flash HC: 9020 How to fix it? Quote:
Swups give me same message with flash ID:BA20 and the same text. No swup works on my phone after I have downgraded once from v20. BUT WINSWUP WITH *.XBI WORKS FOR ME FINE. It's worth to give it a try! (no matter how many times I have erased flash from phone and have reflashed it, flash ID remains the same with all sw: BA20) But phone works fine | |
08-01-2002, 05:10 | #7 (permalink) |
Member: 8130 Status: Offline Thanks Meter: 0 | I see. My phone has hardware problem as well... Speaker is quiet. How long does the soldering solution with thin wires last in your practice(repairing connection spkr.jpg)? I have heared, that iot might last from 2hours to 2 weeks, but not more (( Changing phone motherboard costs1,5X more than a brand new M35 (( |
08-03-2002, 08:49 | #8 (permalink) | |
Member: 6877 Status: Offline Thanks Meter: 0 | Re: Re: Flash HC: 9020 How to fix it? Quote:
(DarkBear has hardware problems...) Last edited by Sergey[Power User]; 08-03-2002 at 08:51. | |
08-04-2002, 19:46 | #10 (permalink) | |
Member: 8130 Status: Offline Thanks Meter: 0 | Quote:
But it's not good for Sztrovacsek He has hardware problems Phone is his | |
08-05-2002, 00:57 | #11 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | if ur c35 have 2 flash m28w160bt, u can try to resolder them, if not work, u have to replace both of them. this flash is the shame like 3310 has. ( Some of them) If ur c35 have only one flash ic, its hard to looking for the component for replacement.. I have that problem too but only 10% solved. Rgds |
e52 flashing error how to fix it?????????????????? | nofear197979 | HWK | 2 | 10-30-2009 12:07 |
Vagtacho 2.5 to 2.6 killed how to fix it | tiguan | CAR Electronics | 1 | 05-10-2009 15:03 |
k790 noising after experimen flashing to k800 how to fix it ? | fastlink Jogja | Cruiser Suite | 5 | 01-17-2008 19:06 |
v3im lost network after flash! have anybody met such problem and how to fix it? | Corban | Motorola P2k | 4 | 03-24-2007 13:08 |
Flashing About Db2020 How To Fix It This Phone | GUDO-GSM | Universalbox | 1 | 09-19-2006 18:04 |
