x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
10-02-2002, 21:25 | #50 (permalink) |
No Life Poster Join Date: Jul 2001 Location: EU
Member: 5423 Status: Offline Thanks Meter: 10 | To all who has problem with Dongle! 1. Device ID is checksum of all hex bytes from 000-FFF in bin file. That is reason why I get Device ID 2D61. I bought Atmel PIC and put bin file inside, but bin file contains bytes from 000-FE2 and rest from FE3-FFF was default from chip 0X00, I changed fields from FE3-FFF to 0XFF, and finaly get Device ID 4A44. 2. Important is voltage between pin 10 and 20 on the pic, must be 4-5V. On some PC I get 2,66V and that is smal value for this PIC. You need external power till 5V. That means when you start application and choose some log file and when you press "Save MAP" you must to have 4-5V between PIN 10 and PIN 20 on the PIC. 3. Pin 10 on PIC must be connected to GND(but rest scheme is OK) For fast PC you can use oscilator between 18-20MHz. If you make this three option you will get 100% working Map creator Enjoy WBR |
10-02-2002, 22:40 | #51 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2001 Location: Cyprus
Member: 4003 Status: Offline Sonork: 100.111841 Thanks Meter: 39 | Hi World Here Atmel 89c2051 and 89c4051 programmer software and hardware schema Best Regards.... Software: Winat32 Hardware: DL2MT Last edited by Special@gsm; 10-02-2002 at 22:45. |
10-03-2002, 09:24 | #57 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Croatia Age: 45
Member: 4185 Status: Offline Thanks Meter: 3 | Problem with BA 20 and CE 20 isnt in MAP files.......ALL map files are the same for old and new c45.........problem is in WRITING calculated data to phone.......looger cannot write it successfully to the phone when u choose C45 in the logger..........thats why you need to upload map to phone as sl45 or use free c45 map writer for new id,and thats why direct free unlcoker for c45 cannot work............ |
10-03-2002, 12:18 | #59 (permalink) |
Banned Join Date: Nov 2001 Location: IRAN Age: 38
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | PROGRAMMER FOR AT89C4051 IS HERE : http://chaokhun.kmitl.ac.th/~kswichit/easy1/easy.htm |
10-03-2002, 16:52 | #60 (permalink) | |
No Life Poster Join Date: Jun 2001 Location: Moscow Age: 40
Member: 5014 Status: Offline Thanks Meter: 0 | Quote:
Thanks VSH | |
sonyericsson total tools dongle hex file for exchange? | gzsunshine | Exchange Section | 2 | 05-02-2003 20:16 |
Maxim Dongle bin file needed in Intel HEX format!!! | Yasser | Siemens-Benq RingTones and WallPapers | 5 | 02-20-2003 16:20 |
HEX & Siemens dongle for sale, Free shipping | Tip | Main Sales Section | 0 | 09-24-2002 03:26 |
I want hex file for Dongle Siemens | leelunth | x1x to x45/x50 | 2 | 06-27-2002 10:38 |
I want hex file for Dongle Siemens | leelunth | x1x to x45/x50 | 0 | 06-27-2002 05:03 |
