x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
04-20-2003, 09:31 | #1 (permalink) |
Insane Poster Join Date: Feb 2003 Location: Saigon, Vietnam
Member: 22487 Status: Offline Thanks Meter: 0 | Graphical Menu's BUG |
04-21-2003, 11:21 | #2 (permalink) |
Major Poster Join Date: Nov 2002
Member: 17688 Status: Offline Thanks Meter: 0 | Andi_HUYVU, There's no icon on mine's. AT the top is only text 'C.Broadcast'. All, Can someone check this for me. I think this is a bug From the GFX menu > Setup > Device > Clock > Time/Date. Set and when pressed OK directly exits to the idle menu. Then pressed the right-soft key for normal Main-Menu > Red key > returns to Time/Date entry menu. This should be the position to exit after pressing the OK key to set the time and date. Then I press Red 3 times to exit to idle menu a blank screen with a small icon at top-left appears. (This icon varies if I repeat). Pressed red again and exits to idle. |
GX10i lost all menu's | petercrowe | Sharp | 1 | 02-25-2005 20:03 |
what read stk menu's command ??? | pxcom | Sim Cloning and Scaning | 7 | 02-15-2004 13:28 |
Another bug in graphical menu | xboybg | x1x to x45/x50 | 1 | 02-07-2004 18:10 |
Spanish Menu's - Info | kevdyas | x1x to x45/x50 | 0 | 11-28-2002 17:58 |
