x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
04-15-2003, 00:41 | #1 (permalink) |
Junior Member Join Date: Apr 2002 Location: Surabaya, Indonesia
Member: 11076 Status: Offline Thanks Meter: 0 | How to Repair your dead SL45 / 6688 First, prepare these SW below: 1. All 3/4 2.0.5 crack by XzZ 2. SL45-19_01.flx 3. Logger & Map Maker 4. IMEI Writer These all files are only work in Windows 98 SE Get all SW files here: http://groups.yahoo.com/group/teddy_gsm/ If you have have all those files, then follow these instructions bellow: Before run the program, you must check the cable data, Baud Rate (115kb), and COM port! 1. Run Flasher (aall34 2.0.5_XzZ.exe) - Load File Flash Image -> SL-19_01.flx. - Choose 'Phone Type' -> SL45, DO NOT SELECT 6688, eventhough your mobile is 6688. - Check 'Write Flash', 'Write IMEI', 'Burst Mode'. - Leave blank IMEI number (000000-00-000000-0). - Click 'Init Mobile' then push imediatelly your mobile button ON. - Wait 'til the progress finish (Sending Application, Erase Blocks, Copy Program). - If you failed in this step, just try again. 2. Run Log Reader (A3X#Part1.exe) - Select 'Logger' Tab. - Select 'Model' -> SL45, eventhough your mobile is 6688. - Click 'Read Phone' then push imediatelly your mobile button ON. - Wait 'til the progress finish and the Windows IMEI appears. - Fill the 'New IMEI' with your mobile IMEI w/o last digit (eg. 350017-51-019823) - Click 'Save Log', save the file into the folder and name it as your desire. 3. Run MAP Maker (A3X#Part2.exe) - Select 'IMEI Change' Tab. - Click 'Open Log', then select 'yourfile.log'. - Click 'Save Map', save the file into the folder and name it as your desire. 4. Run MAP / IMEI Writer (Public4.exe) - Select 'Write IMEI' Tab. - Select 'Model' -> SL45, eventhough your mobile is 6688. - Click 'Open Map', then select 'yourfile.map'. - Click 'Write IMEI' then push imediatelly your mobile button ON. - Wait 'til the progress done. 5. FINISH, Enjoy your mobile again ;-) |
04-16-2003, 07:34 | #2 (permalink) |
Insane Poster Join Date: Feb 2003 Location: Saigon, Vietnam
Member: 22487 Status: Offline Thanks Meter: 0 | I've just downloaded SL45-19_01.zip but can't unpacked it. I downloaded again but nothing changed. So, somebody can give me the link to download this file? Thanks. |
04-16-2003, 18:43 | #4 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Re: How to Repair your dead SL45 / 6688 Quote:
That was a good solution, sometime ago, but now itīs a waste of time and battery. And just using 2 programs... Flash -> SL45i / 6688i http://www.drug-store.itgo.com/SiemensPageFirmSL45i.htm Unisiemens: http://www.drug-store.itgo.com/SiemensPageFls.htm Ksie5.1: http://www.drug-store.itgo.com/SiemensPageLog.htm Best regards | |
How to repair your LG u880 | Dengel | LG | 41 | 10-20-2012 13:55 |
HOW TO REPAIR A DEAD SHARP GX29 or HOW TO FIND THE BEST FILES OF GX29 ??? | Eagle7 | Sharp | 3 | 06-02-2008 20:42 |
** how to got your dead motorla in test mode without force cable ** | MR PROTEC | Motorola P2k | 13 | 02-09-2006 00:16 |
How to Repair your dead SL45 / 6688 | teddy | x1x to x45/x50 | 0 | 08-07-2002 11:13 |
