x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
04-16-2002, 20:18 | #1 (permalink) |
Junior Member Join Date: Apr 2002 Age: 44
Member: 11054 Status: Offline Thanks Meter: 0 | Howto change IMEI of SL45 ??? What do I need for ?? I although wanted to update it to SL45i (FW 43), but the Software always shows an error: "Can´t connect to mobile with BootstrapLoader on Com1". |
11-19-2002, 14:20 | #3 (permalink) |
No Life Poster Join Date: Mar 2001 Age: 44
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Solutions Read the log from you phone and write you original IMEI. After that calculate log wia Mapper. And write back to phone map file. That all. |
11-20-2002, 20:37 | #4 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Use Logger 4.03 Enter in Logger section, connect the phone (COM-port), and press "Read Phone", will asked to enter manually the Imei. Then press "Ok". Save *.log file. Now use A3x, All Doer Enter, and press "Open Log", select the log file you´ve made, and press "Save Map", save *.map file. Now, re-use Logger 4.03 Enter in Write IMEI section, press "Open Map", select the map you´ve created, and press "Write IMEI". Now you´ve resolved your problems and it´s unlocked. Downloads at my Yahoo Group (Must be an Yahoo Registered User): Logger 4.03 http://groups.yahoo.com/group/drug_store/files/Siemens/ In Loggers&Mappers/Loggers&Mappers section A3x, All Doer http://groups.yahoo.com/group/drug_store/files/Siemens/ In Loggers&Mappers/Loggers&Mappers section (named A35_A40.ZIP) Good Luck |
any trick of change imei of 2680 | ranagaurav | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 01-24-2010 00:19 |
Howto Change Imei On Downgraded 3220´s | charlienqn | Universalbox | 4 | 03-21-2007 14:23 |
Where or how i can change IMEI on SL45 phone ? | jonwillow | x1x to x45/x50 | 0 | 10-21-2001 11:57 |
Changing IMEI of 821 | NokiaStuffNL | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 16 | 04-18-2001 01:12 |
Change Imei of 5110 | Vilsa | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-19-1999 14:44 |
