x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
11-03-2002, 12:47 | #1 (permalink) |
Junior Member Join Date: Nov 2002 Location: Antalya//Turkey Age: 52
Member: 17400 Status: Offline Thanks Meter: 0 | I am beginner at flashing Mobiles (Sl45) Thx for help I ll very appriciate.. |
11-03-2002, 14:55 | #2 (permalink) |
No Life Poster Join Date: Sep 2002 Location: EEPROM damaged Age: 44
Member: 15315 Status: Offline Thanks Meter: 1 | - first make an fubu with unisiemens - than flash the latest update with winswup you don't have to flash an fubu with unisiemens. Just make an update. |
11-04-2002, 15:15 | #3 (permalink) |
Member: 17400 Status: Offline Thanks Meter: 0 | Fubu means bakingup existing flash is it correct?Or? Unisiemens flash's everything in the phone is it? And winswup makes with SW *.bin file only update,is it? Do I have to check flash numbers or etc on the phone?Not flash version! I have Sl45i_sw52_fubu, sl45i_fw52_fubu_by dopemaster, sl45i_fw52_fubu_by rugge, sl45i_fw52_fubu_by donmega! which one of them I cld use? Thx, DisPatch |
11-17-2002, 03:28 | #4 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | 1- Yes FUBU means full backup of your phone (flash & EEprom) 2- Unisiemens doesnīt flash the phone and EEprom at the same time. You must flash the phone and them the EEprom 3- Yes, Winswup update sw to your phone, not winswup sw, but the sw that you use with winswup. 4- No, you have to check the version, because downgrade may kill it and then you need to use map and log calculation to reanimate him. TIP: If you donīt have many experience, start by upgrade (ex:v06 to v19) always up, donīt downgrade. Upgrading it may lock you phone to network, if itīs to v23 you can get some sw to unlock it, if itīs higher than v23, youīll need to create map. 5- My advise is to make your own FUBU file. Create it with Unisiemens from an SL45 working perfectly. |
New Application For Watching Tv At Ur Mobile S60 | TWISTER_FLasher | Nokia Multimedia | 47 | 03-14-2008 07:18 |
I Am Looking For New Mobile Phones | elmehdi59 | Wanted Products | 0 | 10-13-2007 05:42 |
K300 error HELP!!!! i am new at this....thanks | Maykoid | SonyEricsson (USB-Smart) | 7 | 02-07-2006 06:10 |
where can i find epprom 24lc256 at any mobile ? | halongmobile | Blazer | 5 | 11-04-2004 20:41 |
all softwares avalible at www.mobile.box.sk...do you want help, contact me | sidharthaharish | BF, BG, TH, BHx Series | 0 | 12-16-2001 10:05 |
