x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
03-13-2003, 18:09 | #1 (permalink) |
Freak Poster Join Date: Mar 2003 Location: London Age: 37
Member: 24408 Status: Offline Thanks Meter: 1 | imei change illegalises phone? anyway, i was jsut thinking, if the phone has an imei number that's not recognise, might this accidently happen? another thing, if the police get hold of it and want to check if it's stolen, when they type in the imei number and no results come back ,they'll no it's not the phone's original, whcih immediatly makes them assume it's stolen. they'll take the phone, and give you a warning. am i right? |
03-13-2003, 18:19 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: U.K Age: 35
Member: 18319 Status: Offline Thanks Meter: 0 | Yes dude you are right. Am in the uk as well. however let me correct you there just a bit. the way that they ( the networks) block it is they type the IMEI number on to there system and then you make it as there network wont regs the imei when the phone is swiched on. so therefor no network, if the police chacht you with a fone that has had it's imei changed. then they will ask you were did you get the phone from. Or they will asum that you did it therefore you will get 5 year in jail!! and for that matter every phone shop in the uk has the police come in as that i meen small shops not the link dixons t-moble ect ect.... i Hope this makes it clear for every one in the Uk ! |
03-13-2003, 19:04 | #3 (permalink) |
Member: 24408 Status: Offline Thanks Meter: 1 | so if a network do block an imei number from their network ,making unusable according to them, a simple imei change will make it work again? and ther's no harm done to the phone? |
03-13-2003, 19:16 | #4 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Many siemens models wonīt work after changing the IMEI... The only model Iīve made IMEI change and it worked was on C / M / and S 35. The Network Block by IMEI, itīs mostly used on Nokias... |
03-14-2003, 10:38 | #5 (permalink) |
No Life Poster Join Date: Apr 2002 Location: West Midlands, UK
Member: 11099 Status: Offline Thanks Meter: 5 | What would happen if I did for instance a back cover change on a phone. Got the back from a scrap handset. Now the IMEI inside the phone would not match the IMEI on the back. If the police get this phone would they think I have been changing IMEI's???? Where obviously I have not. I assume they would have to prove it. For all of us in th UK carrying out repairs, it may be a good idea to keep the damaged back, just in case. |
03-14-2003, 14:54 | #7 (permalink) |
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Ok, if you say so... I never seen and couldnīt change IMEI into a SL45. And Robbie we both know about SL45 with wrong IMEI, right? what intend to happend? Wrong sw, just light up and etc... |
03-14-2003, 14:57 | #8 (permalink) | |
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Quote:
03-14-2003, 15:19 | #9 (permalink) | |
Member: 18319 Status: Offline Thanks Meter: 0 | Quote:
Thankyou | |
03-14-2003, 20:14 | #11 (permalink) |
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | "quote: -------------------------------------------------------------------------------- Originally posted by Drug_Store And Robbie we both know about SL45 with wrong IMEI, right? what intend to happend? Wrong sw, just light up and etc... -------------------------------------------------------------------------------- what do you meen by this please explain a bit more Thankyou" Many siemens phones needs reparacion because of wrong IMEI written with flash or on unlockment procedure. Oh another simple questio... If itīs able to change the IMEI and the phone works ok, what happend when other phone uses the same IMEI you use? The network will grant access to 2 phones with same IMEI? Thereīs something wrong on this tail... |
IMEI change chinese phone | reaz.com | Infinity-Box | 13 | 11-30-2009 20:22 |
Gx29 Imei Changed Restart Phone!! | volkangsm2 | Sharp | 1 | 05-04-2007 13:58 |
info for imei change se phones for all models, step by step??? | saidgoren | SonyEricsson (USB-Smart) | 1 | 05-03-2006 14:37 |
IMEI change after phone dead | hkmodem | SonyEricsson (USB-Smart) | 3 | 10-17-2005 20:44 |
imei change but phone has 2 different no. ? | reo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 02-28-2002 23:28 |
