x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
06-03-2004, 18:13 | #1 (permalink) |
Junior Member Join Date: Jun 2003 Location: Poland Age: 41
Member: 32384 Status: Offline Thanks Meter: 0 | M35 dead, tried basic solutions, help plz! I can swap batteries and then I can still work with it with Freia, tried another fubu's found on the net, both over and under V18 yet nothing works. Since now I managed to find all the answers I needed in the archive but now I'm helpless I will be grateful for any aid or tips Arashi |
06-07-2004, 01:40 | #2 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Try CM3505repair.bin. This will revive your phone for sure. But EEprom will never be as it was... But as u already flashed a FUBU, EEProm is screwed already, so at least will put phone working. |
06-08-2004, 20:02 | #3 (permalink) |
Member: 32384 Status: Offline Thanks Meter: 0 | Thanks for a tip, but... I got one from http://www.honzahavana.com/unblockEN.htm, I found there also this solution http://www.honzahavana.com/Odblokfw18-25EN.txt Unfortunatly, it didn't work. I used Siemens Workshop, uploaded cm35repeai0504.bin as it's written there but after that I cannot use swup. It seems it cannot connect. I might have once used freia set to C35 instead of M35, can it be the reason? If You can help me with another solution, it would be great!!! Arashi |
lg kh1200 need unlock solution..help plz | justin888 | LG | 2 | 12-17-2008 21:10 |
Please help!!! Lg tu515 v10f from rogers dead trying flashing, please help | ligasa | LG | 0 | 10-31-2008 23:02 |
d600 micro solution ?? help plz | rirou | Samsung Hardware Repair | 4 | 06-24-2008 13:34 |
6280 dead after rehot PA help plz | jimmylamz | Nokia Hardware & Hardware Repair | 9 | 11-25-2006 10:36 |
a35 dead after speaker solution,help | mohammed | x1x to x45/x50 | 0 | 05-03-2003 00:28 |
