x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
01-14-2002, 18:03 | #1 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Germany
Member: 6087 Status: Offline Thanks Meter: 0 | @OrbiTel ! my eepromdata are already damaged. new mapfile don`t reanimate the phone :-( i mean:<br />-i need a eepromdump (64 kb) from a sl45iv49<br />-also a fullflash binfile of this<br />-a soft that able to write into sl45i any other idea? do you know the eeprom adresses in hex???<br />regardz Proggy |
01-15-2002, 10:46 | #2 (permalink) |
No Life Poster Join Date: Jan 2001 Location: CZ Age: 44
Member: 3041 Status: Offline Thanks Meter: 0 | Hi man, you can repair your phone only with good map creator software & flashupdate ... <br />Make you log, and send to calculation. After this proces flash your phone with good SL45 flash and phone mus starting. Well ! <br />OrbiTel |
01-17-2002, 10:46 | #5 (permalink) |
Moderator Join Date: May 1999 Location: Blagoevgrad, Bulgaria Age: 52
Member: 73 Status: Offline Thanks Meter: 539 | 1. Make Full Backup from low version<br />2. Put full flash to damaged phone (to restore eeprom)<br />3. Flash with original siemens flash.<br />4. Put map file to phone ... or next solution! 1. Use P35INITMAP (original siemens software) with *.MAP file from siemens XXXX..._1_ ..XXXX (Standart file) and XXXX... _2_...XXX (delta file) .... Standard file is enought... to RESTORE EEPROM VALUES and then restore imei and simlock values with generated map file ... This is universal solution for siemens phone to return from darkness ... Regards: Victor
__________________ You'll die as you lived in a flash of the blade, in a corner forgotten by no one You lived for the touch for the feel of the steel One man, and his honor. |
01-17-2002, 10:59 | #6 (permalink) |
Member: 73 Status: Offline Thanks Meter: 539 | ... small info about P35init. Map files maded by siemens contains checksum at end of file. If u wanna make corrections to file need to be crack ReadMapSimfile.DLL After this u can make corrections. Cannot calculate fields but u can write fields to phone. [XXXX]<br />.....<br />.....<br />Service = 0 {Don't change field}<br />.....<br />..... [XXXX]<br />.....<br />.....<br />Service = 2 {Put to field DATA from section DATA }<br />.....<br />..... [XXXX]<br />.....<br />.....<br />Service = 4 {FILL field values with values from section DATA} Regards: Victor!
01-18-2002, 09:51 | #8 (permalink) |
Member: 73 Status: Offline Thanks Meter: 539 | Ofcourse ... <img src="smile.gif" border="0"> if u have password for <a href="http://communication-market.siemens.de" target="_blank">http://communication-market.siemens.de</a> Regards: Victor
