x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
05-27-2004, 13:58 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: HUN Age: 43
Member: 34029 Status: Offline Thanks Meter: 0 | Questions about sl45 Can somebody answer my questions below? 1. Has somebody tried to synchronize sl45 with computer with IrDa? Does it need a program or hardware? Is that possible anyway? 2. In a java application: "read maniac": wich is the string that makes an "enter" or a "line feed" in the wiew of a txt file? 3. My recorded vmo playback sound is often goes ununderstandable: it plays back scrach sounds and volume goes down for 5 (rarely for 30) seconds. Somebody knows how to fix that? Is that possible? Does my speaker died? Will it be better if I trie with a good quality microphone? But how can I join in the plug into sl45's plug? I can't buy a translator! I'll write more questions when they are actual. Others may write therirs. |
05-27-2004, 19:17 | #2 (permalink) |
No Life Poster Join Date: Mar 2004
Member: 60520 Status: Offline Thanks Meter: 0 | 1. It's possible to connect SL4x via IrDA. But I think, the Data Exchange Software (DES) only runs via data cable. Maybe a newer version, look at www.siemens-mobile.com for this. You can run AT-commands via irDA, that's no problem. 2. What exactly is your problem? The string to make an "enter" (new line) is the "new line"-string or -char, that you can produce with Windows notepad by editing the file and pressing your enter key... Secondly, you can't edit your files in Read Maniac. Please try "Micro Reader V1.0", it's free, faster for reading files AND you can edit them in phone comfortably, even set a new line in the text. 3. Don't know, but the quality is bad, in every case. I use a filter program (Cool Edit 2000) to filter the noise and scramble. Did you listen to your vmo files on PC? Try "vmo2wav", it sets the loudness to the maximum level. |
06-02-2004, 20:44 | #3 (permalink) |
Member: 34029 Status: Offline Thanks Meter: 0 | 4. Does somebody know cell broadcast topics? If anybody has topic list, please write down here. I know the "50" which displays the area where you are currently. 5. Make java game sounds to headset only. To rc-flitzer: When I open a txt file in Read Maniac it doesn't show line feeds just spaces. So I ask which character I should put in my text in PC to have a line feed in the Read Maniac? |
06-07-2004, 16:09 | #4 (permalink) |
Member: 34029 Status: Offline Thanks Meter: 0 | Again if someone can help: 1. Does somebody know cell broadcast topics? If anybody has topic list, please write down here. I know the "50" which displays the area where you are currently. 2. Make java game sounds to headset only. |
06-10-2004, 11:16 | #5 (permalink) |
Member: 34029 Status: Offline Thanks Meter: 0 | 3. Eliminate or adjust the 2 minutes standby exit function (when you leave your phone at everywhere expect the main screen it returns to that after 2 minutes exiting from for example a game or an sms). 4. Wich is the string for keyboard number:1 in patches? |
07-07-2004, 10:49 | #6 (permalink) |
Member: 34029 Status: Offline Thanks Meter: 0 | news Hi 1. Put name search function to mp3-player list. 2. Make java game sounds to headset only. 3. Eliminate or adjust the 2 minutes standby exit function (when you leave your phone at everywhere expect the main screen it returns to that after 2 minutes exiting from for example a game or an sms). 4. Wich is the string for keyboard number:1 in patches? To IrDa question: D.E.S. v267 really can see mobile during IrDa connection: U can make directories, renaming, but U can ONLY COPY FILES that are under 5 KBYTE! That's very poor. But U can copy files to mobile with the internal (in the computer) IrDa managing software. (It will make a tmp file and you rename it to the original name, then it will work). MoDrone |
07-07-2004, 21:56 | #7 (permalink) |
Crazy Poster Join Date: Jan 2004 Location: Brno Age: 39
Member: 51508 Status: Offline Thanks Meter: 0 | ------ You are using windows Irda data copying. You are not using siemens data exchange. You must instal irda and in SiemDataExch klik on Irda. When I was instaling the SDE it asked me and tested it. So I tested if my Irda software is working. |
question about superdongle data of n-95 8gb | compue | Universalbox | 2 | 03-29-2010 15:16 |
One Question About Cruiser,pls | Gubby_J | Cruiser Suite | 2 | 03-29-2010 12:46 |
Question about SL45 and Siemens MP3 Reader. | miriddin | x4x, x5x Flashpatching | 1 | 06-12-2003 11:32 |
Question about F0.13.14 tamper alert question | mr_x4you | Motorola Old Legacy (EMMI) | 0 | 02-26-2003 08:38 |
Question : SL45 to SL45 i ..... Got v49 but don't know how. | keeekeee | x1x to x45/x50 | 2 | 01-24-2002 07:55 |
