x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
06-23-2004, 05:42 | #1 (permalink) |
Crazy Poster Join Date: Jun 2004 Age: 40
Member: 69918 Status: Offline Thanks Meter: 0 | DEAD sl45, please help!!! I tried to upgrade my sl45 from sw54 to sw56 whit WinSwup 32, and in the middle of the flashing progress i will get an error, now i canīt do NOTHING whit the pHone, i canīt replay the process beacuse i always found an error. The phone donīt turn on..iīm desperate. Anyone could help me? I begin to flash beacuse i was trying to repare a error like this: http://forum.gsmhosting.com/vbb/showthread.php?t=97124 If anyone could help me.. Thank you! PD:Sorry my bad english |
06-23-2004, 12:33 | #2 (permalink) |
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | Really the same error? EELite Block bla bla bla corrupted? I hope you've made a backup of your phones software. Or much better from your EEP. Try to reflash the EEP into the phone. Use UniSiemens or V_Klay to do this (links can be found via google) If you haven't any Backup then download a fubu www.gsm-multifund.de / Siemens / FUBU / SL45.... I think Freia can flash these. Freia can also be found there Good Luck with that But please try to save YOUR EEP or your battery parameters, you'll escape some trouble |
06-23-2004, 18:37 | #3 (permalink) |
Member: 69918 Status: Offline Thanks Meter: 0 | I have a backup, but i have maked this backup when my sl45 have the error of EELite Block...in sensor tools. After make this backup i begin to flash the phone, and now is dead. Now i canīt reflash the phone beacuse when the progress start in UniSiemens, it stop an 1% 4% etc, in flash and eeprom.. Do you know other site were i can found FUBU? i can get it from that site: www.gsm-multifund.de |
06-23-2004, 19:39 | #4 (permalink) |
Member: 69918 Status: Offline Thanks Meter: 0 | I already have FUBU, but when i try to write it to my phone whit unisiemens, the progress stop at 1%. Freia say me this: COMM_LoadBoots : Waiting to power on the phone ... COMM_LoadBoots : phone is powered on COMM_SendBoot : boot file is not accepted any idea?? Last edited by Repent; 06-23-2004 at 22:31. |
06-23-2004, 22:43 | #5 (permalink) |
Member: 42457 Status: Offline Thanks Meter: 1 | try http://sl45.darkzone.lu there is annother Fubu Downloadz / Firmware / SL45 Repairkit (it should include all programms you need) |
06-24-2004, 00:11 | #6 (permalink) |
Member: 69918 Status: Offline Thanks Meter: 0 | Ok i have donwloded it, but what i have to do? all i tried not found, unisiemens always stop flashing at 1% I canīt erase-upload a new flash whit any program, because it alwais stop at x%. It coul be because i begin to flash whit a corrupt eeprom?? How i coul fix it please?? HELP!!! Last edited by Repent; 06-24-2004 at 06:45. |
06-24-2004, 07:33 | #7 (permalink) | |
Member: 42457 Status: Offline Thanks Meter: 1 | Hmmm really, weired I occoured the same problem for a long time, I think I changed the data cabel to solve this..... but don't know which one. I've got four data cabels. First the Syncstation - with this you should really solve all problems. Then an original siemens data cabel (from S45) only good for patching nut useable for unlocking or backup firmware (just tested with c45). Then two well cheap data cabel with 3 wires in it (really no electronic) I think they are called M-Bus cabel - There's no flash patching possible, but unlocking and fubu... maybe it's this?? Last chance, try V_Klay as flasher - maybe it's a bit more stable as UniSiemens (I really use only UniSiemens for making Backups) Quote:
06-24-2004, 08:12 | #8 (permalink) |
Member: 69918 Status: Offline Thanks Meter: 0 | I have a sl45 cabel, i will try.. I canīt backup and canīt reflash now Iīm using Syncstation always, but i canīt flash whit V_Klay or do anything. I donīt know waht else to do! Thank you for your help!! |
06-24-2004, 09:51 | #9 (permalink) |
Member: 42457 Status: Offline Thanks Meter: 1 | well last attempt, dump question I know. Have you pressed the red button? It could happen when EEProm is damaged that flash programms don't recognize mobile when it's inserted into the Syncstation. Try following....use your favourite flasher Insert the phone into the station (connected to PC, and power cable inserted) and press red button for a short time (maybe one second) Don't give up if it's not working the first time, give more tries Good luck btw... you can't kill x35 and x45 series (SL4x included) with flashing, the bootcore is implented in hardware so it's IMPOSSIBLE to make the SL45 NOT BOOT anymore! The last possibility is that your phone got a hardware damage but I'm 100% sure that's not the problem here (hope you don't have throwen it to the wall coz it's not working ) |
06-24-2004, 12:46 | #10 (permalink) |
Member: 69918 Status: Offline Thanks Meter: 0 | My SL45 is now alive! I used the data cabel of the s45 to flash whit FUBU,i liberate the phone and now its ok Thankyou verymuch cyperghost! You have saved my phone BUT i have other problem, i will open other post for it. Thanks!! |
DEAD SL45 PLease Help | Anonymousness | x1x to x45/x50 | 1 | 03-23-2003 17:13 |
Dead sl45 please help | paulsta | Phone Unlocking Codes & Maps | 4 | 11-10-2002 01:26 |
how can i unlock the phone coode from sl45 please help | denis10 | x1x to x45/x50 | 1 | 08-12-2002 04:28 |
DEAD S25!!! Please help | davix | x1x to x45/x50 | 5 | 05-18-2001 16:12 |
Dead T10s.. please help ! Thanks | Salute | Old Ericsson Phones & Sony Phones | 1 | 11-02-2000 03:50 |
