x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
04-06-2003, 12:20 | #1 (permalink) |
Junior Member Join Date: Oct 2001 Location: Bulgaria, Targovishte
Member: 7094 Status: Offline Thanks Meter: 0 | Siemens A3x, HC:C289 (0089-88C2) flashing problem That Siemens A3x i have tried to FW update (for language changing). Siemens SWUP194 gave me an error "the flash MID: 0089, DID: 88C2 = Intel 28F160/28F016 Top 16MBit will be erased ..mobile reported invalid flash_block_adress!" Siemens WinSwup32 (SVN: 31) gave me an error "Wrong Erase-Adress, not possible from 0h to F7FFFh" After that changing lang was not succsess, but phone was still a live. I have tried Ziemens x3x Workshop 1.22, it gave me an error and after that phone was killed. Tried a lot of flashers, but nothing... BTW i suppose the phone is some asian version. Original FW was v.16 Some idea to repair phone? |
04-06-2003, 18:03 | #2 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Europe
Member: 7690 Status: Offline Thanks Meter: 4 | Exist more solution... SOLUTION 1: Use All 3/4 Siemens Service v2.0.5 (cracked by Xak) 1. Load *.flx file 2. Select COM Port and mobile type 3. Check option "Write Flash" 4. Check option "Write IMEI" 5. Check option "Burst Mode ( 10% faster ) Now U are ready to flash the phone... 6. Press "Init Mobile" and follow the program instruction's Afther flashing U need to read LOG file from phone &create a MAP file... 7. Use "Siemens IMEI Writer, Version 3.00" or 4.00 <-- read LOG and make MAP file 8. Now use " Siemens IMEI Writer, Version 3.00 " or 4.00 <-- to write MAP file to phone Afther writing MAP file to phone, your phone is ready for calls... Now is "All Done..." SOLUTION 2: 1. Read full flash and eeprom of GOOD A3x with UniSiemens 4.00 2. Then write on BAD phone 3. Use "Siemens IMEI Writer, Version 3.00" or 4.00 for repair & unlock phone good luck _____________ -=G3=- Last edited by -=G3=-; 04-06-2003 at 18:09. |
04-07-2003, 09:26 | #4 (permalink) |
Member: 7094 Status: Offline Thanks Meter: 0 | Thanks, phone live Thanks, G3! I repaired it using All34. Wrote in back MAP file which backuped before all with KSIE51. Now phone works fine, but I still can't find flx file with LP05 (Bulgarian). Other way is flashing with Unisiemens, but it gives me I/O error after bootloader is uploaded. Only All34 works for me, but I need LP05 flx file. |
04-07-2003, 21:07 | #5 (permalink) |
Member: 7690 Status: Offline Thanks Meter: 4 | sorry man i don't have this *.flx only A35_20_06_flx A35_23_02_flx A35_25_06_flx try this 1. Before, Run "Usimload.exe" (9,728 bytes) 2. then "UniSiemens.exe" (594,944 bytes) P.C. "Usimload.exe" must be in same folder. UniSiemens.exe v4.00 working only with COM1 ______________ best regards -=G3=- |
siemens a3x display problems | trafix | Siemens Hardware Repair Area | 4 | 08-29-2002 15:55 |
I need siemens A3x 2004 flash file.zip | gsmsoft | x1x to x45/x50 | 3 | 01-23-2002 09:24 |
Siemens A3X Flash v25 with Russian lng | Mr_Ice | x1x to x45/x50 | 0 | 11-03-2001 09:55 |
Siemens A3x v23 flash? | Bojan20 | x1x to x45/x50 | 10 | 08-30-2001 21:47 |
siemens A3X flash rider | free_gsm | x1x to x45/x50 | 0 | 05-14-2001 11:54 |
