Siemens C35 Could u please help, how to unlock Siemens C35i? |
Hi ! Therefore u have to wait. But u can check something. Type in when phone is on. *#06# and then the upper left key. Then look for Version number. If it is five try to unlock it with all25 and in the same operation. But be careful, maybe your phone is dead. Read the instruction careful and don't turn off phone at the end of the process before diconnected from cable. S25/C35i/S35 uses the same cable. The actual all25 is 2.8 (written above the IMEI input field) if problem write here. b.R. GSM-Lupo |
Hello GSM-Lupo Can u send to me a ALL25 2.8, I want to try. Thanks |
Can u send me 2.8....or where I can download...thanks in advance |
hi GSM-Lupo! also me, pls send a1125 2.8. i want to try it too. thanks in advance. ([email protected]) |
Hi Lupo May you send me all 25 v2.8 I have an all25 working, but know it hang my computer before i give IMEI IMEI field is not writen in screen and then i can only do a reset. My files are in c:\siemens, and statist.bin in siemens\test\tmp May you send me a working file? ------------------ |
Hello elari !! If u already have 2.18 an it hangs up, I think u don't read instructions. Run this prog only in DOS !!!! mode. Sometimes in DOS it hangs too. Then u have to press F8 before booting and after that u boot in MS-DOS mode without loading config.sys and autoexec.bat !! OKAY, no drivers like himem .... !! Then it shouldn't hang up !! b.R. GSM-Lupo |
U find 2.18 here !! http://server32.hypermart.net/coolpage23/s_soft.htm Try too for others .. http://server32.hypermart.net/coolpage23/n_soft.htm http://server32.hypermart.net/coolpage23/e_soft.htm |
[QUOTE]Originally posted by GSM-Lupo: [B]U find 2.18 here !! http://server32.hypermart.net/coolpage23/s_soft.htm Well I only saw 2.16 a couple of times. Not a new version here. Where is it then...? tnx |
Has anyony tried this software, ....How about the result, is there any problem? I haven't tried yet because I'm waiting for cable |
I tried with a new S 35, phone was dead in few seconds, dont do it. We all have to wait for a new software to unlock 35 series. |
Is there anything new on this matter ? |
Hello friends, on www.gsmfactory.com/software you can download for C35/S35. I have done, but i have no idea how i can use this soft. Can anybody help me ??? Thx Vala |
Hi vala ! S35/C35 Service Software can unlock the phones. First install it, than overwrite the default.ini and copy the map directory in the install order. In this there are some MAP's. As standard file select the Standard Map for your phone type. For the second one select the Map which has the name of your phone and of the provider u want to use in it. After that connect phone and start. And u can use your phone in the other provider. U only can use it, if you have the map file without any Providerlock information or the Map for your provider. Clear ? If the right map file is not with your program wait ... !! Because on http://www.gsmfactory.com/ there is a version but the maps are only for a few provider included. b.R. GSM-Lupo |
Hi GSM-Lupo, thanks for your interesting topic, i think its not easy,but i will try. I also try in the next days to make a S35. I will destroy it with newall25.exe and than i try to flash with S35 flasher sw 05. I will give the results to this forum. Bye Vala |
