Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 07-06-2000, 19:14   #1 (permalink)
PNG
Member: 1693
Cool Siemens C35
Could u please help, how to unlock Siemens C35i?
Old 07-06-2000, 21:37   #2 (permalink)
Member: 1651
Sonork: 100.1623070
Thanks Meter: 110
Post
Hi !
Therefore u have to wait. But u can check something. Type in when phone is on. *#06# and then the upper left key. Then look for Version number. If it is five try to unlock it with all25 and in the same operation. But be careful, maybe your phone is dead. Read the instruction careful and don't turn off phone at the end of the process before diconnected from cable. S25/C35i/S35 uses the same cable. The actual all25 is 2.8 (written above the IMEI input field) if problem write here.
b.R.
GSM-Lupo
Old 07-07-2000, 00:53   #3 (permalink)
Member: 65
Post
Hello GSM-Lupo
Can u send to me a ALL25 2.8, I want to try. Thanks
Old 07-07-2000, 03:03   #4 (permalink)
PNG
Member: 1693
Post
Can u send me 2.8....or where I can download...thanks in advance
Old 07-07-2000, 03:49   #5 (permalink)
Member: 1585
Thanks Meter: 15
Post
hi GSM-Lupo! also me, pls send a1125 2.8. i want to try it too. thanks in advance. ([email protected])
Old 07-07-2000, 14:11   #6 (permalink)
Member: 1296
Post
Hi Lupo
May you send me all 25 v2.8
I have an all25 working, but know it hang my computer before i give IMEI
IMEI field is not writen in screen
and then i can only do a reset.
My files are in c:\siemens,
and statist.bin in siemens\test\tmp
May you send me a working file?
Old 07-07-2000, 21:15   #7 (permalink)
Member: 1651
Sonork: 100.1623070
Thanks Meter: 110
Post
Hello elari !!
If u already have 2.18 an it hangs up, I think u don't read instructions. Run this prog only in DOS !!!! mode. Sometimes in DOS it hangs too. Then u have to press F8 before booting and after that u boot in MS-DOS mode without loading config.sys and autoexec.bat !! OKAY, no drivers like himem .... !! Then it shouldn't hang up !!
b.R.
GSM-Lupo
Old 07-07-2000, 21:17   #8 (permalink)
Member: 1651
Sonork: 100.1623070
Thanks Meter: 110
Post
U find 2.18 here !!
http://server32.hypermart.net/coolpage23/s_soft.htm
Try too for others ..
http://server32.hypermart.net/coolpage23/n_soft.htm
http://server32.hypermart.net/coolpage23/e_soft.htm
Old 07-08-2000, 14:05   #9 (permalink)
Member: 1659
Question
[QUOTE]Originally posted by GSM-Lupo:
[B]U find 2.18 here !!
Well I only saw 2.16 a couple of times.
Not a new version here. Where is it then...?
tnx
Old 07-12-2000, 05:46   #10 (permalink)
PNG
Member: 1693
Wink
Has anyony tried this software, ....How about the result, is there any problem? I haven't tried yet because I'm waiting for cable
Old 07-12-2000, 06:11   #11 (permalink)
Super Moderator
GSMWorld's Avatar
Member: 16
Sonork: 100.1652085 GSMWorld
Thanks Meter: 1,743
Post
I tried with a new S 35, phone was dead in few seconds, dont do it. We all have to wait for a new software to unlock 35 series.
__________________
Wbr
GSMWorld
Old 07-28-2000, 10:58   #12 (permalink)
PNG
Member: 1693
Question
Is there anything new on this matter ?
Old 07-28-2000, 22:47   #13 (permalink)
Super Moderator
GSMWorld's Avatar
Member: 16
Thanks Meter: 1,743
Exclamation
Hello friends,
on www.gsmfactory.com/software you can download for C35/S35. I have done, but i have no idea how i can use this soft.
Can anybody help me ???
Thx
Vala
__________________
Wbr
GSMWorld
Old 07-30-2000, 21:16   #14 (permalink)
Member: 1651
Sonork: 100.1623070
Thanks Meter: 110
Post
Hi vala !
S35/C35 Service Software can unlock the phones. First install it, than overwrite the default.ini and copy the map directory in the install order. In this there are some MAP's. As standard file select the Standard Map for your phone type. For the second one select the Map which has the name of your phone and of the provider u want to use in it. After that connect phone and start. And u can use your phone in the other provider.
U only can use it, if you have the map file without any Providerlock information or the Map for your provider. Clear ? If the right map file is not with your program wait ... !!
Because on http://www.gsmfactory.com/ there is a version but the maps are only for a few provider included.
b.R.
GSM-Lupo
Old 07-30-2000, 21:33   #15 (permalink)
Super Moderator
GSMWorld's Avatar
Member: 16
Thanks Meter: 1,743
Post
Hi GSM-Lupo,
thanks for your interesting topic, i think its not easy,but i will try. I also try in the next days to make a S35. I will destroy it with newall25.exe and than i try to flash with S35 flasher sw 05. I will give the results to this forum.
Bye
Vala
__________________
Wbr
GSMWorld
How can i remove(reset) my siemens C35 logo?? yaser x1x to x45/x50 7 05-08-2001 02:09
DEAD SIEMENS C35 slava x1x to x45/x50 3 04-27-2001 20:00
DEAD SIEMENS C35 slava x1x to x45/x50 0 04-24-2001 13:32
Siemens C35 v17 Invader x1x to x45/x50 2 03-29-2001 00:41
Siemens C35 ver05 Unlocker AL x1x to x45/x50 13 03-24-2001 14:31
Page generated in 0.22065 seconds with 9 queries
