x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
03-22-2001, 14:42 | #5 (permalink) | |
No Life Poster Join Date: Feb 2001 Location: Mumbai [India]
Member: 3503 Status: Offline Thanks Meter: 2 | Quote:
MY PHONE SAYS C35 - 'Phone disabled - enter network key' SOFT IS READING INFO C35 I V 05 SENDING APPLICATION ********* THEN NOTHING HEPPENED I WAITED FOR 5 MINS I TRED AGAIN SAME RESULT PLEASE HELP | |
03-22-2001, 15:42 | #6 (permalink) |
Freak Poster Join Date: Nov 1999
Member: 707 Status: Offline Thanks Meter: 0 | Use this http://phonesoft.kgb.cz/x35_spu20byjic.zip tested by me in C35 versions 05 and 12. Please select rigth soft version and Model (C35 or S35)! Regards |
03-23-2001, 07:23 | #7 (permalink) |
Member: 3503 Status: Offline Thanks Meter: 2 | yes i used that soft also but same problem my phone is c35 v 05 so i gave command for c35 i v 05 then unlock soft says power on phone i power on the phone prog finds c35 v 05 then sending application ########### then nothing heppens i waited for five minutes nothing happened so i disconect phone i put sim card in but phone still shows phone disabled network code i tried for two time help me |
03-24-2001, 02:03 | #8 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Hi all! I used the serv. soft. x35_srv.exe. It was very easy, just chousing the right file of the version of my phone and Make Jobs. All done. |
03-24-2001, 07:44 | #11 (permalink) |
Member: 3503 Status: Offline Thanks Meter: 2 | thank all of you i had taken my phone to another unlocker in my country Bcause i had poor luck with siemens in past i had F U C K E D my two c25s and i had to give new c 25 for them in exchange i can not flash my mobile from dos it always says after sending data no connection i am using celeron 533 the person who unlocked my c35 v05 has first tried with normal procedure but phone was locked then he flashed with his laptop is it fault with computer or else? because total flasher from pro is working ok thnak you again gsnbhagawan |
03-24-2001, 08:17 | #12 (permalink) |
No Life Poster Join Date: Nov 2000 Age: 47
Member: 2553 Status: Offline Thanks Meter: 3 | hi, i have the same problem sometimes with some Siemens Phones, i can't unlock them with my computer at home but with my other computer at work, no problem at all, so it is your computer that is causing the problems WBR Meam |
03-24-2001, 08:35 | #13 (permalink) |
Member: 3503 Status: Offline Thanks Meter: 2 | HI Meam what is your processor i have intel 810 chip mother board and cpu celeron 533 mhz what is yours? is there any thing to do with bios so great people in forum can you help me for this problem because my luck is bad for siemens and i am desperate to reoair my c 25s and i dont have to go to other people because of siemens i have lost many costemers i am not unlocker i generally repirs hardware regards gsnbhagawan |
03-24-2001, 14:31 | #14 (permalink) |
Member: 2553 Status: Offline Thanks Meter: 3 | hi, to be honest i don't know what the chip inside my Computer is, i just know, it's a pentium III and it is Intel what kind of problem do you have with your C25? may be your Computer is okay and you just don't have the right Swup or the right flash file WBR Meam |
how to unlock siemens c35 version 20? | carlito | x1x to x45/x50 | 1 | 06-03-2010 13:26 |
How can i remove(reset) my siemens C35 logo?? | yaser | x1x to x45/x50 | 7 | 05-08-2001 02:09 |
DEAD SIEMENS C35 | slava | x1x to x45/x50 | 3 | 04-27-2001 20:00 |
DEAD SIEMENS C35 | slava | x1x to x45/x50 | 0 | 04-24-2001 13:32 |
Siemens C35 v17 | Invader | x1x to x45/x50 | 2 | 03-29-2001 00:41 |
