x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
04-13-2003, 19:52 | #1 (permalink) |
Freak Poster Join Date: Mar 2003 Location: Salonica Greece
Member: 24095 Status: Offline Thanks Meter: 0 | Simple question |
04-13-2003, 23:35 | #3 (permalink) |
Member: 24095 Status: Offline Thanks Meter: 0 | I'm interested only in the battery settings.So if i load a full flash the battery settings don't change right? I'm confused because when i load the good eeprom (with good battery values) all the pics on the phone change. The correct order is first load the good eeprom and then the full flash file right? Please correct me if i'm wrong. ThanX a lot |
04-14-2003, 00:51 | #4 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Re: Simple question Quote:
So write new eeprom only after wrirting full flash. | |
04-14-2003, 01:01 | #5 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Be Age: 48
Member: 3081 Status: Offline Thanks Meter: 8 | Flasing that phone with xbi files you will let the the eeprom area untouched, so if you write an good eeprom in your phone you will have the settings of that eeprom, after that if you flash the phone, with xbi files the eeprom it will remain intact.Xbi files have only firmvare and language pack inside, no eeprom zone. Regards Fludor |
04-14-2003, 01:37 | #6 (permalink) | |
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Quote:
He asked about full flash. Learn more about this here: http://forum.gsmhosting.com/vbb/show...5&pagenumber=2 Or ok, Iīll transfer info into here: "Hi Let me correct you... Swup itīs a program in DOS that updates phone software. Of course thatīs just a program, and it needs to load a flash like others. Winswup32 itīs same program but this time for Windows. Also need to load flash file. And using this programs wonīt write your eeprom, because this just writes the flash. Thatīs why you should use this if itīs just to update firmware of the phone. With full flash, all will be written, including eeprom. This will cause "Wrong Software" on the screen, a black square, just lights up beep and go off, or 100% dead. Always after writing a full flash (that itīs not from your phone)into your phone, youīll need to map your phone to write correct IMEI, or write your eeprom backup. For this kind of flashing I advice you to use Unisiemens. Hope helped you out... Regards" | |
04-14-2003, 02:18 | #7 (permalink) |
Insane Poster Join Date: Feb 2003 Location: Saigon, Vietnam
Member: 22487 Status: Offline Thanks Meter: 0 | @zalaros If you write full flash, the current EEPROM will be overwritten. So if you want to write full flash to your phone without losing current EEPROM, just write from 0x000000 with size 5F0000 (not 600000). |
Simple Questions From a Simple Person | Jekmyster | Sony Ericsson | 0 | 09-18-2007 06:48 |
simple question needs simple answer!!! | hairyeyeball | Nokia Base Band 5 ( BB-5 ) | 1 | 09-07-2006 15:44 |
Simple question, please simple answer regarding A920 | peshta | Motorola P2k | 0 | 05-03-2005 23:26 |
Simple question about algorithm used to generate unlocking codes | drzonca | x1x to x45/x50 | 1 | 02-16-2002 16:17 |
Simple question about 3210 | jivkobg | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-04-2001 23:06 |
