x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
09-08-2002, 17:30 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | SL45i v54 JAVA Activation !!! Intruction in English. "Einverstanden!" and wait for 10 secs. Then it starts. Go to "Optionen" tab. Select the com port where your phone is connected and choose a baud rate (if it wont work try 57600). Then uncheck the "Handy Infos beim Verbinden anzeigen". Go back to "Info Seite" tab and check "FullBlock 5005 (FW 54 Only). Click "Verbinden!", wait a second and press many times the power on button on your sl (but dont power on the phone! - try many times, or if it won`t work try connecting your phone 1 second after pressing "Verbinden!" instead of pressing the power on btn) until your phone displayes "Service mode" on its screen and then click "Java freischalten...". It will ask you "EEPROM Bearbeiten?", click yes. It would be done in secs. And after completion maybe you will have to confirm something. Just click ok. Now turn on the phone and you hava Java! Need Sw upgrade v54 for SL45? Sent me a mail, and IŽll sent it !!! Need JAVA Activator? Sent me a mail, and IŽll sent it !!! Try it, and youŽll see... Drug_Store - Portugal [email protected] +351 934968065 |
09-08-2002, 18:15 | #2 (permalink) |
Junior Member Join Date: Sep 2002 Location: Glasgow
Member: 15222 Status: Offline Thanks Meter: 0 | You can download Java Activator from the following URL if you want: http://www.vicecom.de/gsm-free/Sieme...aaktivator.zip I upgraded to v54 and enabled Java but now I cannot unlock my SL45. Any known issue regarding unlocking SL45 fw54? I already opened a topic regarding that issue but no success so far: http://forum.gsmhosting.com/vbb/show...threadid=55266 |
09-08-2002, 18:44 | #3 (permalink) |
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Yes, the same thing append to me, when I already have it unlock on SL45 v19, after the update to v52 he got locked. Then I give it to a friend that took 2 weeks to unlock it, but after that, never get blocked again, even after repairing and re-flash 4 or 5 times. I guess that it can be unlocked with a map file, but IŽm not really sure. Thanks for the links... Everyone that want JAVA Activator, click on the links provided by Ant |
09-08-2002, 22:58 | #5 (permalink) |
Junior Member Join Date: May 2002
Member: 11818 Status: Offline Thanks Meter: 0 | You can use my new tool, Multitool if you want ! Its available from my private Webspace at www.ts-pc.de or at http://www.gsm-multifund.com/Update/...ool_V1.03a.zip |
SL45i & Java | 468 | x1x to x45/x50 | 7 | 02-20-2003 01:28 |
Sl45i v54 JavaEnabler Repost Please. | throwawayforums | x1x to x45/x50 | 2 | 07-26-2002 22:43 |
SL42 LAG > SL45i with Java - ProBlems ! | meister-schnack | x1x to x45/x50 | 0 | 06-28-2002 15:36 |
SL45i v54 BIN File! | holts | x1x to x45/x50 | 1 | 04-02-2002 22:15 |
