x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
05-18-2002, 13:58 | #18 (permalink) |
Major Poster Join Date: Oct 2000
Member: 2317 Status: Offline Thanks Meter: 0 | Hi Chryse You can download the LogReaders/LogUploaders from www.gsmhacker.com . Best of luck Michael. |
05-18-2002, 14:17 | #19 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Disneyland Age: 47
Member: 8329 Status: Offline Thanks Meter: 6 | hi thanks for prompt reply... what does he meant about no.6 that it is necessary to write IMEI with Siemens IMEI Writer ??? what about the Siemens IMEI writer v3.00 that is free in the net and the Free Mapper... can we use it? thanks man! BR |
05-18-2002, 15:47 | #20 (permalink) |
Member: 2317 Status: Offline Thanks Meter: 0 | Hi Chryse After you're done with the LogUploader, the phone will still be dead (if it is) 'coz it still needs a new map. I have used Map Writer v3.00, myself, and I quite assure you the my mobile is a re-born Siemens C45 . If you feel you'd need more detailed info, pls email me and I'll be happy to lend a helping hand. Best regards Michael. |
05-18-2002, 22:19 | #21 (permalink) |
Junior Member Join Date: Jan 2002 Location: Russia
Member: 8887 Status: Offline Thanks Meter: 0 | Totals: For unlock A3X/A40/SL45/SL45i you need Siemens A3X All Doer v3.00, for CSM35New - All Siemens Service Software v3.00, for C30 - Siemens CMS35 MAP creator, for old CMS35 – ZeeSiemensG3. Links to these free or cracked programs you will find on this forum. For CSME45/S40 use paid services while there is no free calculator. For revival of dead phones (except SME45/S40) use my solution or BleedR program, and WorkShops by PRO. What it's necessary for entirety of happiness! Last edited by aklab; 05-19-2002 at 00:06. |
05-19-2002, 08:48 | #23 (permalink) |
Insane Poster Join Date: May 2001 Location: U.K.
Member: 4562 Status: Offline Thanks Meter: 0 | Tryed on SL45 v52, done everything by the book, upload eeprom succesfully write the map but phone only blinks shortly. So not worked. Don't play whit SL45 After flashing V49 sometimes "wrong software" Any ideea? Best Regards. Last edited by peterwalt; 05-19-2002 at 09:30. |
05-19-2002, 09:19 | #24 (permalink) |
Freak Poster Join Date: Feb 2002 Location: Jakarta
Member: 9261 Status: Offline Thanks Meter: 0 | Working but.... Wrong Softfware hai aklab your solution is working in my A35 & C45 phone. but after phone power on, displayed Wrong Software. and i must make map files for a35 & c45. do you have solution is working without Map files. because i don't have c45 map maker. or maybe you have map maker for c45 program, please send me. thanks for all and sorry for my ENGLISH. |
05-19-2002, 15:32 | #25 (permalink) | ||
No Life Poster Join Date: Mar 2001 Location: Earth
Member: 3506 Status: Offline Thanks Meter: 6 | Dont play with toys if dint know what they do and how to fix it !!! Quote:
05-19-2002, 19:08 | #26 (permalink) |
Member: 8887 Status: Offline Thanks Meter: 0 | 2masterross: 2All: People!!! This solution is not intended for play with working phones! It only for absolutely dead phones which do not switch on or only blinks shortly! But if your phone only is locked or writes on the screen " Wrong Software ", this solution not for you - you should use usual tools (Map Maker, Direct IMEI Writer etc.). And one more nuance: even if your phone is absolutely dead, first, whenever possible, backup full flash or even EEPROM-area because with my solution you write universal Def. EEP and thus lose the Sensor Adjust Data, individual for each phone (customization of the transceiver, battery charging etc.). In most cases you at all will not see a difference but if the phone - your own, you will think, what he, perhaps, works not on all 100% As should work. 2Hary: Sorry, but i don't have CSME45 map maker - try http://forum.gsmhosting.com/vbb/foru...?s=&forumid=71 |
05-19-2002, 21:29 | #27 (permalink) |
Junior Member Join Date: Jul 2001
Member: 5350 Status: Offline Thanks Meter: 0 | HI! I have a C35 with B701 flash and with v24 soft. Eeprom data is full damaged, thats why swup is not enought... Is there a program which can fullflash it? Ziemens and Martech CANNOT! If i do Aklab solution, the lc uploader give the error message: "no data for this phone" I hope it is because, that the logger cannot read the real phone ID, that's why when it tries to upload it isn't match with the ID in the "lc" file. Thanks a lot, Spinergy |
05-19-2002, 21:43 | #28 (permalink) |
Member: 4562 Status: Offline Thanks Meter: 0 | @masteross Phone was bad before Managed to have him powered but not worked well. Soo no problem for me. "Dont play with toys if dint know what they do" BTW I like toys. Bye. P.S. "Dont play with toys if dint know what they do" if the toys are not yours. You'll pay them. |
help with solution for changing imei of T2288 with clip | MichieMax | Motorola Old Legacy (EMMI) | 0 | 04-01-2004 10:55 |
dead A50 v7 with damaged eeprom | mobils | x1x to x45/x50 | 1 | 05-18-2003 17:23 |
any solution for SL45/SL45i with dead eeprom. | sat | x1x to x45/x50 | 2 | 06-02-2002 03:57 |
100% solution for dead C/M 35 with "abnormal termination" in Workshop 1.22 | Chuk | x1x to x45/x50 | 7 | 01-17-2002 18:26 |
