Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 04-13-2003, 19:52   #1 (permalink)
Member: 24095
Simple question
If i load a new eeprom and after that load a full flash for the phone will the eeprom settings be lost? I'm a little bit confused so forgive me for that stupid question
Old 04-13-2003, 20:00   #2 (permalink)
Crazy Poster
Member: 24557
You will obtain the settings of the new epprom loosing your old config.
Old 04-13-2003, 23:35   #3 (permalink)
Member: 24095
I'm interested only in the battery settings.So if i load a full flash the battery settings don't change right? I'm confused because when i load the good eeprom (with good battery values) all the pics on the phone change. The correct order is first load the good eeprom and then the full flash file right? Please correct me if i'm wrong. ThanX a lot
Old 04-14-2003, 00:51   #4 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
Re: Simple question
Of course that if you write new eeprom, write full flash, the eeprom you wrote will be deleted...
So write new eeprom only after wrirting full flash.
Old 04-14-2003, 01:01   #5 (permalink)
Fludor's Avatar
Member: 3081
Thanks Meter: 8
Flasing that phone with xbi files you will let the the eeprom area untouched, so if you write an good eeprom in your phone you will have the settings of that eeprom, after that if you flash the phone, with xbi files the eeprom it will remain intact.Xbi files have only firmvare and language pack inside, no eeprom zone.
Regards
Fludor
Old 04-14-2003, 01:37   #6 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
Regards
Fludor
But xbi isnīt full flash...
He asked about full flash.
Learn more about this here:
http://forum.gsmhosting.com/vbb/show...5&pagenumber=2
Or ok, Iīll transfer info into here:
"Hi
Let me correct you...
Swup itīs a program in DOS that updates phone software. Of course thatīs just a program, and it needs to load a flash like others.
Winswup32 itīs same program but this time for Windows. Also need to load flash file.
And using this programs wonīt write your eeprom, because this just writes the flash. Thatīs why you should use this if itīs just to update firmware of the phone.
With full flash, all will be written, including eeprom. This will cause "Wrong Software" on the screen, a black square, just lights up beep and go off, or 100% dead.
Always after writing a full flash (that itīs not from your phone)into your phone, youīll need to map your phone to write correct IMEI, or write your eeprom backup.
For this kind of flashing I advice you to use Unisiemens.
Hope helped you out...
Regards"
Old 04-14-2003, 02:18   #7 (permalink)
Member: 22487
@zalaros
If you write full flash, the current EEPROM will be overwritten.
So if you want to write full flash to your phone without losing current EEPROM, just write from 0x000000 with size 5F0000 (not 600000).
Old 04-14-2003, 11:06   #8 (permalink)
Member: 24095
Now it's all clear and fully understanding Thank you all of you for the precious help
Simple Questions From a Simple Person Jekmyster Sony Ericsson 0 09-18-2007 06:48
simple question needs simple answer!!! hairyeyeball Nokia Base Band 5 ( BB-5 ) 1 09-07-2006 15:44
Simple question, please simple answer regarding A920 peshta Motorola P2k 0 05-03-2005 23:26
Simple question about algorithm used to generate unlocking codes drzonca x1x to x45/x50 1 02-16-2002 16:17
Simple question about 3210 jivkobg Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-04-2001 23:06
Page generated in 0.18346 seconds with 9 queries
