E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
09-11-2003, 20:53 | #1 (permalink) |
Junior Member Join Date: Sep 2003
Member: 38302 Status: Offline Thanks Meter: 0 | C55: battery empty, please recharge! thanks. |
09-11-2003, 21:34 | #2 (permalink) |
Insane Poster Join Date: Nov 2002 Location: Romania Age: 46
Member: 17466 Status: Offline Thanks Meter: 0 | I guess that U are sure that the charger is OK, if so The phone see when U plug in the charger?? If the phone say that is charging but is not then in most cases is a chip in the phone that control the charge that is faulty or the charging current is too low due to a malfunction of the current regulator in the charger... |
09-15-2003, 11:02 | #3 (permalink) |
Member: 38302 Status: Offline Thanks Meter: 0 | the phone says it is charging but after some time the battery empties. charger current is 9v when not plugged in the phone. is it ok? it says on the charger it outputs 5v. please check your charger and tell me the voltage. if it's the chip, how can it be solved? perhaps battery calibration? thanks. |
09-15-2003, 21:13 | #4 (permalink) |
Member: 17466 Status: Offline Thanks Meter: 0 | Hi! U measure the tension (9v) and is not necessary wrong... U should check the Amps of the charger... It must be between 150 and 500 mA (0.15 to 0.5 A) ... |
09-15-2003, 21:21 | #5 (permalink) |
Member: 17466 Status: Offline Thanks Meter: 0 | If the charger is ok then it's the chip and I don't think the battery calibration will do any good... At this time I don't know for sure what chip is responsible for charging in C55 but I hope to find out tomorrow and I'll post here... |
mc60 battery empty please recharge solution! | infogsm | Siemens Hardware Repair Area | 12 | 04-05-2007 04:25 |
C200 Battery Empty Please Recharge | haider | Samsung Hardware Repair | 0 | 09-05-2006 12:41 |
Battery Empty! Please Recharge! HUGE PROBLEM! | mokhabarat | Siemens Hardware Repair Area | 16 | 04-20-2006 12:26 |
A50 battery empty please recharge | usernome | x1x to x45/x50 | 3 | 01-17-2005 10:57 |
c55 says batery empty,please recharge!! HELP!! | yuberto | E-Gold Based Phones | 3 | 06-17-2003 16:53 |
