E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
06-12-2003, 14:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: no where Age: 43
Member: 4121 Status: Offline Thanks Meter: 11 | c55 ver18 Wrong Software Help Me!!!! C55 ver 19.... Unlock a50-c55 unlocker phone bizzzzz!!!! Write full flash ksie soft ver 18 full flash and read log send online map users... And write map phone wrong software Unlock ****** and other soft phone bizzzzzz!!!!! upload new eeprom and new map orginal imei phone wrong software!!! Help me Thanks!!!!! |
06-12-2003, 15:17 | #2 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Portugal Age: 50
Member: 6358 Status: Offline Thanks Meter: 10 | just unlock it, with a50-c55 unlocker. If it has unsupported flash ID (Micron, 2C17), only with map. If this doesn't work, check imei with a50-c55 wizard, read original imei (from flash) and compare with actual imei (eeprom). If not the same, copy the original and write it on the eeprom one. You see the program "comunicating with encryption unit", leave it for 5 seconds, then close program (don't stop the writing). You'll see the program "writing imei". |
06-13-2003, 08:20 | #7 (permalink) |
No Life Poster Join Date: Dec 2001 Location: [☾✫ ] Age: 58
Member: 8159 Status: Offline Thanks Meter: 98 | @volkangsm 1- fullflash the phone with the full_flash which comes with the files. 2- write the eeprom 3- write the hdd data area 4- then in the imei_ing tab, first read the Original Imei(Flash Chip) In this case the fullflash option should be enabled by the tab Flashing 5- copy the imei and then read the Actual Imei in the tab ImeIing when you read it, it is another imei, 6- paste the copied imei and in the Flashing Tab choose eeprom flashing or reading 7- come back to the tab ImeiIng and click the Write Imei. wait for about 5 min 8- don't stop the option!!!! just close the program! you will see that the program says writing Imei!!! and that is it! the telephone live |
06-13-2003, 17:05 | #8 (permalink) |
Member: 6358 Status: Offline Thanks Meter: 10 | Man, I guess you need instruction manual even for getting laid... I have repaired several C55 with wrong soft and didn´t need to put any full flash, just by repairing the eeprom imei with Wizard and then unlocking with A50-C55 Unlocker. Only if you have totally dead phone, you´ll need to put another flash. Best regards |
WRONG SOFTWARE... help me | xxmenxx | x1x to x45/x50 | 4 | 01-10-2004 14:43 |
A50 to C45 - Wrong Software! Help! | alex92 | x1x to x45/x50 | 3 | 04-22-2003 10:21 |
C26 v61 Wrong Software! Help me! | yayi | x1x to x45/x50 | 6 | 07-15-2002 20:17 |
c45 wrong software,help? | gsmsalers | Phone Unlocking Codes & Maps | 6 | 05-07-2002 22:15 |
Siemens C25 V51 wrong software .HELP | igor_m | x1x to x45/x50 | 1 | 08-12-2000 16:23 |
