E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
04-23-2009, 05:35 | #1 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1016073 Status: Offline Thanks Meter: 0 | CF110 can't flash I have cut the right trace, and use Joker 0324/0356 is the same Get Info... MobileMode: Normal HWID: 250 (AL21) A21C lg8 Sw03 20.01.06 15:04:51 IMEI: 358757000349087 DisplayID: 62, Sharp Nec PD161700 FSN: 4DF6DEED SW FlashID: 0001/2221 Code(04): OTP open Code(08): BootKEY is unknown Code(0C): Keys miss in BCORE (CleanBCORE) Code(13): Complete access to BFB Code(15): Complete condition Code(1A): Block 76 is accessible Code(1C): Block 5123 is not found Battery Voltage 3944 mV. SecurityMode: Factory DSP Firmware Version 00, Power Asic Project ID: 21, RF Chipset ID: 0A EELITE Info: free buffer 109886 bytes, free at all 109990 bytes, free for deleted 109990 bytes. EEFULL Info: free buffer 77292 bytes, free at all 223820 bytes, free for deleted 92892 bytes. Battery Ri measurement: CutOff Idle: 3457mV, CutOff Talk: 3571mV, CutOff Idle: 3412mV, CutOff Talk: 3549mV, CutOff Idle: 3415mV, CutOff Talk: 3535mV, CutOff Idle: 3415mV, CutOff Talk: 3535mV. Operating time: Total 27464528 sec, Current SW 27464528 sec. Talk time: Total 232244 sec, Current SW 232244 sec. CSD: Total 0 bytes, Current SW 0 bytes. GPRS: Total 1034685 bytes, Current SW 1034685 bytes. |
04-25-2009, 11:36 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
Try to make firmware update with the AL21 software file. If not working, fullflash again your phone with the correct fullflash file FOR CF110, NOT OTHER... dagos | |
Can't flash NEC 338 | angel25dz | NEC | 0 | 03-29-2010 12:25 |
CF110 spanish flash for joker please | celutek | E-Gold Based Phones | 2 | 08-19-2008 18:50 |
A35-can't flash, can't unlock, can't log! | Migeni | x1x to x45/x50 | 4 | 12-21-2002 12:17 |
