E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
12-02-2003, 21:03 | #3 (permalink) |
Insane Poster Join Date: Dec 2003 Location: Jupiter
Member: 45410 Status: Offline Thanks Meter: 0 | Thanks for the soft, how about the Test point? I have used the soft to unlock A50 (after connecting the test point), but I dont know the test point for A52. I need your help. Thanks. |
12-02-2003, 22:07 | #4 (permalink) |
No Life Poster Join Date: May 2003
Member: 28435 Status: Offline Thanks Meter: 16 | www.siemens-java.com => freai bulit 8 |
12-07-2003, 20:39 | #7 (permalink) |
Member: 45410 Status: Offline Thanks Meter: 0 | This is how to unlock A52 Hai ! folks, I have got the answer. To unlock A52 get , Freia 8 select A52 then go to configuration setting select bootcore bug . Click Ok. Then Click unlock , then choose direct unlock save map . Click Original IMIE . If your phone is not unlock something most be wrong with your cable. Good luck. |
12-20-2003, 23:26 | #9 (permalink) |
Freak Poster Join Date: Feb 2003 Location: POLAND Age: 46
Member: 20822 Status: Offline Thanks Meter: 3 | @ HOPE YOUR SOLUTION DONT WORK: COMM_LoadBoots : selected phone family is 11 TTY_OpenCOMPort : opening COM1 COMM_IsBootRunning : bootcode does not seem to be running COMM_LoadBoots : Waiting to power on the phone ... COMM_LoadBoots : phone is powered on COMM_SendBoot : boot file is not accepted P.S. CABLE 1000%OK TESTED ON C/S55 100000 TIMES !!! |
12-20-2003, 23:36 | #10 (permalink) |
No Life Poster Join Date: Jul 2003 Age: 39
Member: 33290 Status: Offline Thanks Meter: 1 | i heard dat A52 v 7 have 2 kind of.it have hardwear dive die one kind is working with friea but another one says boot file is not accepted.and it should be unlocked with testpoint |
12-22-2003, 21:41 | #12 (permalink) |
Member: 45410 Status: Offline Thanks Meter: 0 | You do not need Test point to unlock A52 You do not need Test point to unlock A52. Go to configuration setting, try the 3 options. If it does not unlock checkl your cable, or hardware problem. thanks. |
12-22-2003, 21:53 | #13 (permalink) |
Member: 45410 Status: Offline Thanks Meter: 0 | tell us the software version you used and the steps hai! @ GENIP You did not tell us the software version you used and the steps you took, so that we can help you. Thanks. Hope |
12-22-2003, 23:31 | #15 (permalink) |
Registered User Join Date: Dec 2002 Location: The Netherlands Age: 41
Member: 19168 Status: Offline Thanks Meter: 55 | for unlock A52 new version 7, use FreeToolbox from sst-gsm. tested by me on many phones of a52 when freia says, boot was not accepted. sst free toolbox works great on it, unlock it as c55. |
HOW TO unlock SE v600i ??please help | xiongfuchen | SETool2 | 15 | 05-21-2013 08:10 |
How to unlocking A52? | Karateka | E-Gold Based Phones | 38 | 06-23-2004 06:46 |
A52 V9 how to unlock!!!! | sawa | E-Gold Based Phones | 6 | 05-29-2004 14:58 |
A52 How To Unlock 9version | *Overseasunlock* | E-Gold Based Phones | 4 | 04-09-2004 14:47 |
A52 version 7 how to unlock? | urbian | Siemens-Benq RingTones and WallPapers | 7 | 12-15-2003 11:38 |
