E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
09-08-2003, 22:18 | #1 (permalink) |
Junior Member Join Date: Dec 2002
Member: 18543 Status: Offline Thanks Meter: 0 | some crypted fields in martech 3.9 i found the new martech software 3.9 ;-) new is, that some things (like phonecode, simcard id, simlock) readed from the phone. but all fields are crypted? is there any possibility to decrypt this stuff? steinchen0815 |
09-09-2003, 14:49 | #2 (permalink) |
Junior Member Join Date: Jul 2003
Member: 33392 Status: Offline Thanks Meter: 0 | unlock functions are still only available if you have the box ... ! :-( http://sp.izhevsk.net/Martech_siemes...39_cracked.zip |
09-09-2003, 17:12 | #4 (permalink) |
Freak Poster Join Date: Sep 2003 Location: here Age: 57
Member: 38308 Status: Offline Thanks Meter: 0 | no, because part of the code located in the box. Dont try to unlock your phone with this software, if you dont have a box. Only flash read/write aviable! Firecell |
09-09-2003, 23:09 | #7 (permalink) |
Member: 33392 Status: Offline Thanks Meter: 0 | does read/write really work? If I do not want to unlock any code are you sure that writing of Flashes (they should be FullBackups then) and Eeproms works correctly ? So if I read out the flash and want to reprogramm my handy (because it crashed while trying to downgrade etc.) it works? Its the first soft I see supporting M55 without TestPoints! |
09-10-2003, 12:54 | #12 (permalink) |
Major Poster Join Date: Aug 2000 Location: Down under
Member: 1986 Status: Offline Thanks Meter: 0 | Is there a working flasher for the m55 out??? Why not using Siemens Flasher 1.3??? You just need the correct addresses. Or is the flash-type of the M55 not supported ... ? |
09-10-2003, 22:27 | #13 (permalink) |
Member: 33392 Status: Offline Thanks Meter: 0 | what's the fact now ? M55 ... write flash button is there ... you maybe should use the load file button before ! But 1 killed his mobile with it, one said it's working. Anyone else who made experiences with the M55 ? Usually i'd expect it to work fine since writing Flash/Eeprom doesn't require the Box-Functions ! |
Help with crypting fields | asmax1 | ARM9 BASED M62 / M62+ | 4 | 04-25-2004 22:36 |
My X5 Crypted field | diassynthesis | Phone Unlocking Codes & Maps | 4 | 09-27-2003 01:59 |
SL55 dead by Martech 3.9 cracked | Laser | E-Gold Based Phones | 15 | 09-14-2003 09:35 |
Martech 3.9 | GsmDevel | Siemens-Benq RingTones and WallPapers | 10 | 09-08-2003 16:43 |
Need some info about crypting IMEI in BF3 | Chuk | BF, BG, TH, BHx Series | 4 | 01-23-2003 10:11 |
