E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
01-09-2005, 02:15 | #3 (permalink) |
Junior Member Join Date: Jan 2004 Location: Brazil Age: 45
Member: 50221 Status: Offline Thanks Meter: 0 | thx, KoTsK... I tried, but somehow the program does not recognize my fubu. it's a v-16 lg-5 t9-5... but i'll keep trying... if succesfull, i'll post the results and the the v20 lg-5 t9-5 i'm trying to build. best regards! |
01-09-2005, 20:06 | #6 (permalink) |
Member: 50221 Status: Offline Thanks Meter: 0 | @KoTsK i've seen the same address you have put here, and it didn't work for me... i think it's for sl55 v14, but i have no v14 to test it... anyway, it my work for some people!!! @chrget i'll try it and post results later... @all thx!!! |
01-10-2005, 10:10 | #7 (permalink) |
Freak Poster Join Date: May 2003 Location: Athens, Greece
Member: 29130 Status: Offline Thanks Meter: 5 | You can also try 'Smelter' : http://avkiev.kiev.ua/Siemens/Smelter/Smelter.rar Then open Langpack list , 'right-click' inside and chose 'Save whole langpack' or 'Load whole langpack'. Also if you want to make the correct entry in 'slged.ini' of language editor 1.4, then after openinning Langpack list in 'smelter' go back to Information menu - list. Locate 'Address of langpack' and 'Full size of langpack' and put them as the first 2 parameters in a line for that model. The rest of the line sould be as any other similar model or as the line suggested previously. |
01-11-2005, 00:23 | #8 (permalink) |
Member: 50221 Status: Offline Thanks Meter: 0 | thank you a lot, dsp mobile!!! i'll try to do it to get SLGED properly set for a SL55 v20 lg_01 t9_01. i'll delete 2 languages, and then i'll insert brazilian portuguese into the fubu. wondering if it's gonna work right. also, i'll compile a T9 language created by T9_Base_Creator into my phone using v_klay... hope it works! thanks again!!! gr8 forum, i never thought i would get so much help from so many users! really!!! Last edited by ombuttsman; 01-11-2005 at 01:26. |
01-14-2005, 13:56 | #9 (permalink) |
Member: 29130 Status: Offline Thanks Meter: 5 | T9 packs for various languages are pretty stable, and usually don't change often for new versions. But for LangPack you got to take the desired lang from same version. If it is from an older version of firmware it will probably not work ! Except if the total Number of strings - messages are the same for the 2 different versions there might be a chance to work... |
Need urgently FULL flash for SL55 V16 or upper please | Burnt Cobba | E-Gold Based Phones | 8 | 06-27-2005 13:40 |
Present for RizaPN or Siemens Language Editor 1.3 | DjCook | Siemens-Benq RingTones and WallPapers | 33 | 03-20-2005 21:29 |
I need Full Flash for SL55 V16 ( FLS) pls | flechazo | E-Gold Based Phones | 16 | 07-20-2004 13:42 |
Need flash(firmware) for Sl55 v16 Spanish. | neohard | E-Gold Based Phones | 2 | 02-27-2004 03:22 |
Language editor for Siemens phones. | dankec | Siemens-Benq RingTones and WallPapers | 125 | 06-25-2003 03:51 |
