E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
01-18-2005, 02:03 | #1 (permalink) |
Junior Member Join Date: Jan 2005 Age: 50
Member: 103129 Status: Offline Thanks Meter: 0 | SL56 Big Trouble - Problemas con SL56 Hi fellas. Well, i'll try to brief the situation. I have this SL56 FW v9 (american version for SL55) and it was with a lot of functions locked, included Java downloading, Ir sending and some others. So, i decided to flash it, so i'll get it unlocked. I downloaded this fw and eeprom from http://www.ichhabkeininternet.de/downloads.php and proceed with the flashing task. I used freia and first made a backup for the Fw, the eeprom and the bootcore, and the battery parameters. Then, i flashed out using the downloaded versions of fw, eeprom and bootcore for sl55. The phone didn't start again; now the freia can't write/read from it, after i could efectively write the fw downloaded. What software do I must use to get the phone back in work?... I repeat: the freia did not feel the power on touch anymore, so it can't be flashed again... Thanx in advance, for everybody, from Colombia. Pls reply here and to: [email protected] [email protected] |
01-23-2005, 16:27 | #3 (permalink) | |
Member: 103129 Status: Offline Thanks Meter: 0 | Quote:
Qué necesito pa' traerlo de vuelta?... Gracias compa, | |
01-25-2005, 06:48 | #4 (permalink) |
Junior Member Join Date: May 2004
Member: 64263 Status: Offline Thanks Meter: 0 | Como Su Celular Esta Totalmente Muerto Me Toca Prenderselo Y Actualizarselo Personalmente!! De Donde Es Usted? Colombiano? Bogotano Creo Que Si!! Yo Le Cobro 50.000 Y Se Lo Dejo Como Nuevo!! Es Mas Con La Version 27 Para Que La SeÑal No Le Joda!! Yo Pense Que El Telefono Le Recibia Algo De Info, Pero Como Lo Mato Totalmente Me Toca Verlo,!!!por Ningun Motivo Deje Que Un Tecnico Le Caliente La Tarjeta Para Prenderlo!porque O Si No Lo Pierde Del Todo Espero Su Respuesta |
01-25-2005, 08:53 | #6 (permalink) | |
This is abouot a dead SL56 while trying updating software, through freia, and now it don't give power on nor nothing at all. I hope u understand my poor english | |
problema con actualizacion 5.02 smart clip | dragon_c | Smart-Clip | 4 | 12-10-2009 08:34 |
help you hay un problema con mandar codes | omar_peligro | SMTi | 0 | 09-07-2009 15:43 |
Problema con n82 | LUIS PIPOL | Nokia Hardware & Hardware Repair | 7 | 09-04-2009 18:52 |
problema con vodafone 527 | pora | PolarBox 3 | 1 | 11-24-2008 17:07 |
tengo problemas con blazer | abdo37 | Blazer | 0 | 07-17-2006 21:22 |
