S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
08-24-2005, 09:48 | #17 (permalink) | |
Freak Poster Join Date: Jun 2002 Location: Spain Age: 52
Member: 13239 Status: Offline Thanks Meter: 3 | Quote:
You have all you need into this post, method is same for ver >41. Regards | |
08-25-2005, 10:43 | #18 (permalink) | |
Freak Poster Join Date: Apr 2003 Location: Romania Age: 47
Member: 27330 Status: Offline Thanks Meter: 1 | Quote:
08-25-2005, 11:37 | #19 (permalink) | |
Regards | |
11-22-2005, 18:07 | #20 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | can't unlock c65 v50 i tried to downgrad to lower version with sst but there's a error with swap impossible too. how to do thankx [email protected] |
11-23-2005, 14:30 | #21 (permalink) | |
All about papuas is writed in this post and others, search an read. Regards | |
11-28-2005, 13:16 | #22 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Dubai
Member: 39022 Status: Offline Sonork: 1575244 Thanks Meter: 94 | AutoIgnition... Transmit Boot... Boot loaded ... Pause 2 sec... Retrieve information... FlashID: 0089,880D SIEMENS C65 353661001289000 HASH: 1D13D72D82520CF3B1FFE28E1F04AEC8 OTP ESN: 8A8DE407 OTP IMEI: 353661001289000 All EEP blocks: 229 Block 52,76,5008,5009,5077,5121,5122,5123 found . Old block 5008 saved into 353661001289000_EEP_051128155914_5008 Block5008 not need replace ! Old block 5077 saved into 353661001289000_EEP_051128155914_5077 Block5077 not need replace ! Old block 5121 saved into 353661001289000_EEP_051128155914_5121 Error code command write segment A022B9BE! Impossible replace block 5121! Replace not good- check phone i got this problem my phone can't accept flash and show "flash write error" i try it with x65flasher |
11-28-2005, 15:15 | #23 (permalink) |
Member: 13239 Status: Offline Thanks Meter: 3 | What are you trying to do? it seems like you have check Replace 76, 5008, 5009, 5077 and replace master or something like this. If you want to unlock your phone just follow the right steps, dont play with others, if your phone is already dead, say what have you done, and will try to help. Regards |
11-29-2005, 13:31 | #24 (permalink) |
Member: 39022 Status: Offline Sonork: 1575244 Thanks Meter: 94 | Listen dear before this problem my set show "pik" and x65papua detect this set easily with testpoint and i already make friea.log and map so i try to flash it through x65flasher which show problem than i try connect>bootpassword-manually entry and than putt value in HASH,IMEI and ESN and than it show "calculate bootpassword" and after hour it show stop than i try to reflash but it show "bootpassword -00000000000000" and can't flash x65papua also show imei 0000000000000 in "code tab" before these action i already make backup of eeprom and bootcore file through x65flasher and eeprom tool can't detect this phone how can i repair imei any suggestion |
Siemens EEPROM tool by skylord v3.15 - problem with LOAD ALL option | PSG | Siemens-Benq RingTones and WallPapers | 5 | 07-22-2005 10:21 |
help, error with siemens eeprom tool by skylord | njben | S-Gold Based Phones | 8 | 03-03-2005 08:24 |
Can not connect C65 with Siemens Eeprom Tool | Anno | S-Gold Based Phones | 3 | 12-19-2004 21:38 |
About phone dead by Siemens Eeprom tools | sschn07 | S-Gold Based Phones | 2 | 11-15-2004 11:02 |
does siemens eeprom tools by skylord work under win2k? | eio | Siemens-Benq RingTones and WallPapers | 0 | 05-02-2003 08:24 |
