S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
11-16-2005, 00:21 | #1 (permalink) |
Insane Poster Join Date: Jul 2004 Age: 39
Member: 73867 Status: Offline Thanks Meter: 5 | C75 unlocking step by step:) 2. run x65papuautil newer version and go to Flash menü 3. press start and fast the POWER ON 4. when you see "Pause 2 sec" deconnect the resistor from testpoint 5. go to Codes menü and press CALC SKEY+BKEY, after HASH+BKEY, after power on the phone and press SENd SKEY TO PHONE. 6. for finish save log with Freia.log 7. run mapper and load and create map from saved log 8. POWER ON PHONE and run eeprom tool 3.15 with this option =x65 √ precheck and run it 9. left side load the map file like siemensA50 123451234512345 unlock.map right side load custom 4 item 0076 5008 5009 5076 and update it with map file 10. select all right side and save all 11. press EXIT and have a good day. here is all what you need: http://rapidshare.de/files/7693583/a..._this.zip.html |
11-16-2005, 00:43 | #2 (permalink) | |
Freak Poster Join Date: May 2004 Location: poland, chelm Age: 45
Member: 65489 Status: Offline Thanks Meter: 5 | Quote:
ad 6 if u choose no log is saved papuas unlock ur siemens directly btw i unlock many c75 without open the phone java etc etc search on this forum br | |
11-16-2005, 21:35 | #8 (permalink) |
Freak Poster Join Date: May 2004 Location: Poland, Poznan Age: 38
Member: 66993 Status: Offline Thanks Meter: 12 | Yesi was selected save all But what i need to do now? In eeprom tool I can turn on service mode in phone, but when i push save selected error appear: Error ?15(Wblockinfoquery) while writing block ? 5008... You can retry writing, skit this block or abort whole writing proces. Abort, Retry, Ignore. I found something like that "If You have siemens X65, X70 serie any SW wich only "beep" when You try to power on, You gona need: -PapuaUtilits0.38d(U can use any, but these one is translate on english), 0.46 to work with AMD flash IC-s -Test Point(no mether what sw is in Your phone!!!!!) -V_Klay, X65Flasher, MartechII, SST(original) to do a full flash off Your phone (U don't have to do full flash, try to do the procedure without full flash the phone. If not work, first do the full flash!!!) Make the TP, put Your phone on cable(COM), run PapuaUtilits and go to section "Flash". Check "Recalculate Keys in Flash" and Papua by hem self, cheks "Replace 76,5008,5009,5077", "Replace Master". It's must be checked too "Pause", and You can make "Make Backup".Put TP on the ground , Click on the "DO JOB". Papua say's "Pause 2" and than You relase TP from GND. Papu starts to doing the job. At the end Papua says "Phone need to be Freeze". Then You go to section Settings off Papua, put Your phone in Service mode(must be on the display off phone), go to section "Various". click on "Read IMEI from phone", and when Papua read IMEI from phone click on "Freeze". Take the phone off from cable. If You try to power on the phone...PHONE IS LIVE AGAIN." But when i try to do it papa display: Checking values SKey from page "CODES" ... Using Skey: 65178525 AutoIgnition... Transmit Boot... Boot loaded ... Pause 2 sec... Retrieve information... FlashID: 0089,880D SIEMENS C75 356272009698551 HASH: 98D141F557BECC08AA94A1B9F937E97B OTP ESN: CF423724 OTP IMEI: 356272009698551 All EEP blocks: 198 Not found block52! Working...BCORE... BCORE HASH not need change ! BCORE IMEI not need change ! Boot unllock. Exist someth.! Last edited by haller; 11-16-2005 at 23:32. |
11-16-2005, 23:57 | #9 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: Cochabamba Age: 38
Member: 87396 Status: Offline Thanks Meter: 64 | Quote:
11-17-2005, 02:10 | #10 (permalink) |
Member: 65489 Status: Offline Thanks Meter: 5 | @electrosoft and others i cannot agree with u c75 v11 i unlock via java many phones @japunlock sol. form davidofman is ok but my is faster and very safer (no need eeprom tool) for his sol. add my suggestions ad 5 point after send skey u must open skey ad 6 if u choose no log is saved papuas unlock ur siemens directly and all be okay and remember think think..... |
11-17-2005, 10:46 | #11 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Croatia/Zd Age: 44
Member: 26670 Status: Offline Thanks Meter: 5 | Quote:
11-17-2005, 16:14 | #13 (permalink) |
Member: 65489 Status: Offline Thanks Meter: 5 | what for u use old eprom tool?? 99% problems it is save all in eeprom tool i use for unlock (repair) save log next step cancel and choose yes for next question power on the phone and unlocked ;-) but safer method is reset mastercode to 12345678 and enter manualy to phone ps sorry for my poor english br szmit4 aka deejaybialy |
11-18-2005, 05:23 | #15 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | szmit4 what do u mean Calculate master key how can we do that and unlock PLZ tell step by step how ca we do that.....And as u said above "ad 6 if u choose no log is saved papuas unlock ur siemens directly" What does this mean it unlock direct o need of mapper or Eeprom tool...And is it gona work on cx70 v43 as well and similer mobile versions??? |
*The first Treo 600 Unlock Step By Step by SPguru | spguru | PalmOS /HP and others | 23 | 06-19-2007 08:17 |
c975 ver. 6.3.6 how to unlock step by step please!!!! | clickingmobiles | Motorola P2k | 4 | 12-06-2005 08:56 |
Z105 unlocking step by step plz | reez | TST Dongle | 15 | 12-04-2005 01:33 |
Sharp 902Sh unlock step by step | jignesh_1000 | SonyEricsson (USB-Smart) | 3 | 11-11-2005 20:25 |
Panasonic GD87e unlock Step by Step help needed! | Hixxy22 | Panasonic | 7 | 08-22-2003 13:51 |
