S65 V43 dead, need siemens expert HI, my S65 is dead beaucause i disconected the cable when eepromtool start writing. Now the phone dont power one, only a beep. i have a good eeprom backup but i dont know how to write it i already try with -eeprom tool = sending service boot but the phone beep and nothink -v_klay = error chaouskey2.bin -sst crcked = entering service mode and nothink -paupouas = i can do alll the procedure for unlock, all work Can you help me to rebuild the eeprom area, wich softwre to use, test point or not, is it permanantly dead?:confused: your help will be realy apreciat, thx for all. :) AZIRA |
Use this solution... 1. Connect phone with papua in service mode (custommer)...(you already have SKEY, else make testpoint) 2. Open EEPROM tools and write eeprom backup (that youve made before unlocking) 3. You get some errors that it can't write certain eeprom blocks....just ignore it and resume eeprom writing. 4. After that phone is still dead, but battery settings are repaired then.... 5. So in papua tools you can connect again and use the Recalculate Keys in Flash.... 6. Phone is alive again |
thx for your reply thagansta but the phone dont conect with eeprom tool (beep). with papua i obten this : Checking values SKey from page "CODES" ... Using Skey: 89560968 AutoIgnition... Transmit Boot... Boot loaded ... Pause 2 sec... Retrieve information... FlashID: 0089,880D SIEMENS S65 353912003529053 HASH: 236C4C2F6F5C5BDD173EBDBCB58FD832 OTP ESN: 472DE247 OTP IMEI: 353912003529053 All EEP blocks: 231 Block 52,76,5008,5009,5077,5121,5122,5123 found . Old block 5008 saved into 353912003529053_EEP_051021000028_5008 Block5008 not need replace ! Old block 5077 saved into 353912003529053_EEP_051021000028_5077 Block5077 not need replace ! Old block 5121 saved into 353912003529053_EEP_051021000028_5121 Error code asknowledge command erase segment A022C459! No ask. tocommand writting segment A022C459! Impossible replace block 5121! Replace not good- check phone ! what can i do for rewrite eeprom??? |
try to flash with x65flasher-1072 after that unlock with sst :) |
whith this soft a obten this error : The program failed to read boot password. The procedure exited with error message: No answer from BFC ping:( |
1 Attachment(s) With Winswup flash starting but in few secondes a obten : Erase-Error Block 0 : Error in the command sequence:mad: :mad: :mad: What can i do:confused: |
no idea about this problem??? the phone was dead beacause i have disconected the cable when eeprom tool started writing. Can martech solve my problem? |
my problem is not solved i am waiting for HELP i have not experience in flashing siemens i think in this forum some peaple have good experience in siemens phone thanx in advance for all answers |
look man there's a full solution to repair this kind of mobiles just tey search botton |
Dude just read..... 1. Connect phone with papua in SERVICE MODE (custommer)...(you already have SKEY, else make testpoint) Don't close papua tools....so THEN 2. Open EEPROM tools and write eeprom backup (that youve made before unlocking) |
1 Attachment(s) Quote:
open xpapua go to codes connect phone in service mode try to recalculate than unlock skey then enter skey or try the open all boutton . after go to flasher 1072 clic connect then shotrly pwr on if connect ok flash fone if not select open all in tab selection it will be ok to flash if not searsh in my posts good luck |
for Flasher 1072 , after enter Skey in phone, u need create ini file with x65flasher.ini same method for V_Klay and you need good Flash files |
The similar problem with S65 I have one s65 (v43), who power down every time when i press "power on" button and after confirmation "OK", the phone break down. I flashed the phone with swup (v43) and again the same problem. After that, i flashed phone with SST (full flash witch i downloaded from net), and the phone is now DEAD. I flashed with few version of swups but still is dead. The phone can't power up. EXPERTS, need help!!!!!!:confused: |
