What's the matter with you think before doing any thing, ask your self why you have created and placed the bootloader generated by papua in "V_KLay\data\Loaders" ... Open good your eyes and in vklay -->menu choice of boot choose the bootloader that you have placed in "V_KLay\data\Loaders" Salam |
I use Vklay 3.3 with s65 (Password boot) no select the x65 xxxxxxxxxxxxxxxxxx (xxxx is the imei of fone) |
1 Attachment(s) Quote:
May be it is a problem with my computer?! I dont think so because for resum :
As i have say(write) to you before "think before doing any thing,ask your self and this time why you can connect your with Papuas and you can't with Vklay?" I will respond to you have you try to connect your phone to Vklay via test point? Have you try an other bootloader in the choice menu as SL65 ? Your phone isn't dead, remember you can retreive all info with papua... Salam |
flash any siemens hi there, Buy martech box II, is the most professional siemens machine , with that you will always solve that kind of prblems regards pewy2000 |
All of these problems because of bad RAM IC. You need to change it. |
B.R |
2 Attachment(s) i did some test using a working c65 for now if the problem came by computer or v_klay or cable, ram ic... first i tryed to read flash using c65 (password boot), communication is OK, programme start reading, all is OK. I also try with generated bootloader by papua X65 3547xxxxxxxxxxxx, it is also work. |
2 Attachment(s) in seconde time i retry with my dead S65 using s65 (password boot) and genrated bootloader by papua ; the problem is the same : in few seconde i obten error loader not ready |
i've the same problem with my dead S65 V50 and with erased bootcore and erased eeprom lol more morst than ur probs m8 lol but now after reading all your poste i think the message error generated by V-Klay is due to cable type i think if we use the auto egnition cable the prob will be solved i didn't tryed yet cause i didn't find the cable , but if u can try to use the autognintion USB cable, like SST Box Cable and poste resulte good luck:) |
s65 beep Hi! I've get one S6V with sw41 and only beep. I try papua repair video but No succes: Auto Ignition... Transfer boot... BOOT is loaded... Getting Information... FlashID: 0089,880D BCORE clean! OTP ESN: E79E37FE OTP IMEI: 353910006530482 Write BCORE version: "main_1.0_V22 " Error in confirmation code to command Erase segment A0000000! No confirmation to command to Write segment A0000000! Error writing BCORE segment! Repeat Operation! So what can I do for working again this *** phone Thanks! br Tybee |
