S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
03-09-2006, 16:48 | #1 (permalink) |
Insane Poster Join Date: Oct 2003
Member: 42526 Status: Offline Thanks Meter: 0 | Siemens C72V totally formatted.Need Help I have totally formatted my EEPROM of my Siemens C72V with Papua's FFS_C. Doh! Now phone blinks just when I press the ON/OFF button. What now? No answers from (siemens EEPROM tools, and all the stuff).But Also when the phone was working there were problems with these tools. Clicking on connecting.... of x65flash there was no aswer from the good working phone Does someone think that I need to make an autoignition cable for my phone? I am using a SIEMENS DC-500 COM cable (the one used for S-55 my previous phone.) Does someone think I have to add some stuff like resistor to the cable? Could it help solving the problem no answer from the phone? How can I flash the EEPROM with software that is NOT WINSWUP (because it does not work for me)? B.R. Houseman |
03-09-2006, 18:27 | #2 (permalink) |
No Life Poster Join Date: Jul 2004 Location: GEORGIA,Tbilisi
Member: 75765 Status: Offline Thanks Meter: 722 | Well, well, well ... You dont listen to me, or not doing things correct, UserSWUP must work, check what error it gives, if says cant connect phone to com 1 with speed 115200, it means it is set on this settings and u must connect phone with COM1 and serial cable with 115200 speed ! x55 serial cable needs no resistors or other sh!t to work with x65 ! Try with that fullflash and UserSWUP again, and if u cant do it, write about all your connections and etc ! Alternative variant is x65 flasher by Chaos, but about this later ... |
03-10-2006, 18:27 | #4 (permalink) |
Member: 42526 Status: Offline Thanks Meter: 0 | Hello BB-gsm Believe me.I am not SO stupid as You think :-( I tried all the types of connections and speeds with com port and all possible combinations. Same result. I tell you shortly. IMPOSSIBILITY TO READ/FLASH PHONE: 1)With full working-unlocked phone I connect it at com port1 of a pc set speed to 115200. -Siemen's EEPROM tools -Vlad's -SST v6.50 -x65flasher-1092 when the programs asks me to press shortly ON/OFF button nothing happens!. It seems like the program does not recognise when I press the button (that's why I asked for the autoignition cable...) 2)PROBLEM WITH BOOTCORE: Papua's tells me: when I try in FACTORY MODE to read BKEY bootkey pressing "Read EEP BKEY": "Reading Bootkey from EEPROM... Record Bootkey is absent from EEPROM Can not Read BootKEY from EEPROM!" whY???????????????? IS IT NORMAL? Setting to Service mode in Papua and clicking the button SERVICE MODE it says: Autoignition Boot not loaded Boot released 3)PROBLEM WITH WINSWUP: Laconically says sometimes: "Could not open Comport for BFC-Lib, maybe Comport is in use" WITH ALL APPLICATIONS CLOSED AND THE PC REBOOTED!!! or: SAME OLD fuc**ng msg: "Can't connect to Mobile with BootstrapLoader on Com 1" Have tried with 3other friend 's pc's totally remaking the WinSwup from Papua process. SAME RESULT. Don't know where the problem is. Need help what I am doing wrong. Best Regards HOUSEMAN |
03-10-2006, 20:23 | #5 (permalink) |
Member: 75765 Status: Offline Thanks Meter: 722 | Now I see phone cant be detected by PC, after formatting FFS_C ... Is your cable ok ? Watch this video ... Do as here is shown ... If the result is not working phone, send it to me, I`ll repair it for you ! Regards, B |
03-11-2006, 11:37 | #6 (permalink) |
Member: 42526 Status: Offline Thanks Meter: 0 | Thanks BB-gsm! Now What do you mean if my cable ok? it is an original DC-500 S55 to RS232 serial com port. Do I perhaps need any changes to the cable? like connecting to gnd or vcc some pins? I could do standard operations like reading INFO,IMEI, enter service mode and all the stuff with papua but not works with eeprom tools, siemens ecc. B.R. Houseman |
07-21-2006, 21:31 | #7 (permalink) |
No Life Poster Join Date: Dec 2004 Location: 0x001FD00
Member: 98572 Status: Offline Thanks Meter: 36 | Autoignition Boot not loaded Boot released THis is what exactly happened to me, I keep figuring out, is it the cable problem or not, auto init work or not. I can boot the phone in service if i press the on off button. but cannot boot the phone to service mode using auto init. but using the egold phone it can. |
Total Noob needs help ;.; please | JediKitteh | LG | 1 | 11-09-2008 16:28 |
e530 with limited service total plank needs help!!! | bernieboylee | SWIFT Platform | 7 | 03-13-2006 18:01 |
total newb needs help with u8110 | dan8e11 | LG | 0 | 01-04-2006 19:18 |
Siemens A52 Data cable ..... Need help | dsh2003a | E-Gold Based Phones | 1 | 08-24-2004 19:59 |
Siemens A3x version 21 - NEED HELP !!! | snk | x1x to x45/x50 | 3 | 08-08-2001 17:09 |
