11-28-2002, 11:10 | #1 (permalink) |
Junior Member Join Date: Oct 2002
Member: 16996 Status: Offline Thanks Meter: 0 | Dead SL45.. Situation Critical...Help! I have tried to use ALL3/4 2.0.91 by xzz and flash ver19. Still dead. (click write flash, write Imei) Then i create log and use map, still dead. Then i tried using WinSWUP with ver49, at 100%, says ABORTING due to TRANSMISSION ERROR.. Then i tried drug_store's recommended method, fullflash with v55 on UniSiemens, Still dead. After log, still dead. Also tried to copy eeprom from 100% working 6688, also no hope. Also tried the Siemens EEPROM repairer, but, it always says connecting to bootstrap-loader, no change...never connect. NO lights, no sound...no sign.. Anybody know what to do now? |
01-10-2003, 02:02 | #5 (permalink) |
Junior Member Join Date: Jan 2003 Location: Phils Age: 46
Member: 19692 Status: Offline Thanks Meter: 0 | just how did you manage to charge your batteries since you said that the phones were dead?..... pls. note that during flashing, battery power is used.. that may be the reason for the trouble during flashing.. |
01-12-2003, 00:33 | #8 (permalink) |
Insane Poster Join Date: May 2002
Member: 12263 Status: Offline Thanks Meter: 1 | My frend had like same problem programs that say nothing receive after 2 boot unisiemens that don't write well all flash problem trasmission for many programs Flash idc not correct and so on i maked for u a flash of many little portion of 64 kb (94 file if i remember well of 010000 in esa) and he loads all this files at the right offset so he finally had a good flash in phone and after remap now it work! so u can try this if haven't good result flashing all file of 6 Mg in one time..... Wind |
06-06-2003, 23:17 | #9 (permalink) |
Junior Member Join Date: May 2003
Member: 29573 Status: Offline Thanks Meter: 0 | I guess this post will be of use to newbies like me: I own a SL45i wich originally carried FW52. It is still under warranty, so I took it to a Siemens shop, and they updated it to FW56. I wanted to tweak it a little, so I used V_Klay 2.1.5.2 directly with phone (instead of file) but the "Use only long press of # to unlock keypad" mod KILLED THE PHONE, although I tried to "Undo" the patch! I did have a FW52 flash backup wich I made with UniSiemens 4.0, so I flashed the phone with it (through Sync-Station). But I wanted to get the FW56 back! So... WinSwup (SLIK5601w executable) DIDNīT WORK! I kept getting "Cant connect to Mobile with BootstrapLoader on Com 2" and "Could not switch on Mobile" and, after trying various schemes of powering on/off+inserting in SyncStation, "Voltage 0.000 is to low, please charge" I charged it and the battery was now full, but still I got error messages. I kept trynig dongle emmulator on/off, different COM ports, different COM port settings/speed, but NOTHING WORKED... UNTIL I USED: - data cable (NO SYNC-STATION!!!); - Siemens Dongle Emulator 1.81 - SLIK5601w (winswup32) - checked both "skip" boxes ("pre-check" and "post-check") - "Serial Config": Baud 115200; COM2; uncheck Synch-Station - Press "START"... - As the "Connect mobile" bar moves, press red button on the phone - The "Connect mobile" bar grows, then screen turns ORANGE... ... ... - screen turns sea greenish/blueish... ... ... - DONE! **NOW IīLL BACKUP THE FW56 FLASH WITH UNISIEMENS!!! (THIS IS A REALLY GREAT TOOL FOR FLASHING-WORKS WITH SSTATION TOO ** Last edited by slsl; 06-07-2003 at 02:14. |
DEAD sl45, please help!!! | Repent | x1x to x45/x50 | 9 | 06-24-2004 12:46 |
DEAD SL45 PLease Help | Anonymousness | x1x to x45/x50 | 1 | 03-23-2003 17:13 |
Please HELP with dead SL45 | Permonik | x1x to x45/x50 | 2 | 01-08-2003 09:46 |
Dead sl45 please help | paulsta | Phone Unlocking Codes & Maps | 4 | 11-10-2002 01:26 |
HELP ME PLS! i need the map for dead Sl45 | edward2002ru | x1x to x45/x50 | 3 | 05-26-2002 13:56 |
