12-01-2003, 16:37 | #6 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Italy
Member: 26267 Status: Offline Thanks Meter: 1 | It can be maybe a problem of corrupted firm. Not very probable but possible... Try the patch of vibra icon. Or open your SL45 and check the position of vibra motor and its 2 pins. If your vibra is connected but doen't function, u can buy a new vibra motor, in Italy we can find for 4 or 5 euro. |
12-13-2003, 15:01 | #8 (permalink) |
Junior Member Join Date: Dec 2003 Location: shenzhen china Age: 45
Member: 46245 Status: Offline Thanks Meter: 0 | i think perhaps the vibra is good,but the circuit is break,3 months ago,i opened my sl45i to change the orange lamp to white ones(some tiny white leds).when i closed the covers,the vibra motor did not work, so i had to opened it again,i found that the spring in the vibra motor did not contact to the metal toucher in the main board.so i used a wire join them by an iron. you must make it sure that the spring in the vibra motor contact s to the metal toucher in the main board when you close your covers of sl45i. |
12-13-2003, 16:18 | #9 (permalink) | |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | Quote:
I had the same problem, too ! | |
samsung c 170 has a 2 different type of PWB, incl the LCD,how to switch the lcd?? | mantok | Z3X-Team Products | 1 | 01-25-2010 08:06 |
6131 how to switch on? | fingusio | BB5BOX | 1 | 10-06-2007 19:11 |
How to switch clock on Mot2288 ? | De Moon | Motorola ODM | 4 | 11-14-2003 07:42 |
How do you remove the casing on an sl45? | PixL | x1x to x45/x50 | 0 | 07-01-2002 19:23 |
How to take off front cover on SL45 ? ? ? | bluelights | x1x to x45/x50 | 2 | 09-13-2001 19:01 |
