10-04-2004, 08:45 | #676 (permalink) |
Junior Member Join Date: Sep 2003 Location: romania Age: 38
Member: 39405 Status: Offline Thanks Meter: 0 | ; M55V11: VERTICAL NET & BATT ICONS (AS NOKIA STYLE) ; © KoTsK - 10/09/2004 ; Picture by Toki to work for fw91? When i applied it,after i start the java game,the pictures(nokia batt and signal) dissapeared thanks in advance |
10-05-2004, 14:30 | #678 (permalink) |
Junior Member Join Date: Oct 2004 Age: 43
Member: 85010 Status: Offline Thanks Meter: 0 | can anyone tell me how to extract t9 pack (memory area) from a fubu i created (fw11) cause i upgraded my phone to fw91 and i was only able to extract the lang pack... now some languages do not have t9 |
10-08-2004, 15:24 | #679 (permalink) |
Junior Member Join Date: Sep 2004 Age: 37
Member: 80590 Status: Offline Thanks Meter: 0 | Hello Can somepne convert this patch to M55 v91, please? ;Java auto starter when new SIM is inserted. and phone whant to select default book ;© SiNgle ;M55v10 ;Prog must be there A:\Java\Jam\Prog\Prog.jar ;0D7994: 98809890 FA9F2006 ;4F0F3C: DAB718F8 FA6F580F ;7F05F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FCFE05E6FD7C02E01EFA9178EA ;7F05FE: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 413A5C4A6176615C6A616D5C50726F67 ;7F060E: FFFFFFFFFFFFFFFFFFFF 5C50726F672E6A617200 ;7F0620: FFFFFFFFFFFFFFFFFFFF DA9FF00598809890DB00 ;locale=german And can someone make a patch to protect the filesystem with phonecode? Thanks |
10-08-2004, 22:02 | #680 (permalink) |
Junior Member Join Date: Oct 2004 Age: 49
Member: 85630 Status: Offline Thanks Meter: 0 | M55v10 Digital Clock ScreenSaver Im not able to find the patch for the M55v10 Digital Clock Screensaver I only find the one for the M55v11... Could someone post it? Thanks Also what would be the best way to install it? using V-Klay?? Im a newbie... so help would be nice! |
10-09-2004, 01:25 | #681 (permalink) | |
Freak Poster Join Date: May 2004 Age: 61
Member: 66180 Status: Offline Thanks Meter: 0 | Quote:
;Digi Clock in keylock Mode ;M55 FW10 0DC86A: E6FCB101 DA5500B4 35B400: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00CD7500D00F2F1CE63F2F2CC638820 35B410: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB09E0AEBB1426FC09009810BB03E6FC 35B420: FFFFFFFF B101DB00 35B424: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0A2F6F10EFE5B22F2F10CFE8810F2FE 35B434: FFFFFFFFFFFFFFFFFFFF 0EFEBB0398E0BB01CB00 35B43E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C006FE4C01E6FD1200DA2DCCC498C0 35B44E: FFFFFFFFFFFF 06FC1600CB00 ;*** M55v10: DiGiTaL CLoCK iN SCReeNSaVeR MoDe *** ;© Matr!x - 29/04/2004 ; ;Patch "DIGICLOCK IN KEYLOCKED MODE" must be installed! ;Change "Menu > Setup > Display > Screensaver > Style > Analog clock" ;do not show digiclock on mainscreen when key locked ;0DC86A: DA5500B4 E6FCB101 0E5A54: 88908880 FA5500B4 and all patches are used by V_Klay Last edited by anuroj_007; 10-09-2004 at 01:49. | |
10-09-2004, 06:42 | #682 (permalink) |
Member: 85630 Status: Offline Thanks Meter: 0 | I tried the following patch: ; *** DigiClock in KeyLocked mode **** ; M55 v10 ; by ACiD [mrp], RizaPN ; Loader: V-Klay 2.4+ / M55 000DC86A: E6FCB101 DA5500B4 0035B400: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00CD7500D00F2F1CE63F2F2CC638820 0035B410: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB09E0AEBB1426FC09009810BB03E6FC 0035B420: FFFFFFFF B101DB00 0035B424: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0A2F6F10EFE5B22F2F10CFE8810F2FE 0035B434: FFFFFFFFFFFFFFFFFFFF 0EFEBB0398E0BB01CB00 0035B43E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C006FE4C01E6FD1200DA2DCCC498C0 0035B44E: FFFFFFFFFFFF 06FC1600CB00 But all I see is strange characters.... What can I do to see digits instead of strange characters?? Last edited by hsantos; 10-09-2004 at 07:57. |
10-09-2004, 08:14 | #683 (permalink) |
Member: 66180 Status: Offline Thanks Meter: 0 | @ hsantos you need apply digital picture patch too this is one digi picture http://forum.gsmhosting.com/vbb/show...2&postcount=22 and you can use other digi pictures for v11-v91 it uses same graphic patch for big digi clock but picture number must begin only 332 to 343 !!! and if you need show digi clock in screensaver mode you should apply this patch ;Hide Analog Clock M55v10 ;(c) KoTsK 3849BC: E4 00 anuroj_007:Siemens M55 FW07-->FW10-->FW11-->FW91-->FW10+patches: |
10-09-2004, 15:18 | #684 (permalink) |
Member: 85630 Status: Offline Thanks Meter: 0 | I dont have a v11-v91!! Can I still use the patches for a v91 in my M55? Also what would be the sequence to install all the patches: 1- DigiClock in KeyLocked mode 2- Digi Pics 3- DigiClock in Screensaver THanks |
10-10-2004, 00:14 | #685 (permalink) |
Junior Member Join Date: Feb 2004 Location: Stari Banovci, Serbia & Montenegro Age: 39
Member: 53902 Status: Offline Thanks Meter: 0 | Clock problem Hello, I have a strange problem, so if someone can help me it would be great! Because I have tried too mutch new patches for my M55 v91, it got a few bugs. So I decited to write back my clean fubu and start over patching with only the needed tested patches. It all worked great, and my phone is working very good, BUT HERE IS THE PROBLEM: Every time I turn off my phone, and on again the date & time gets crazy. It shows everytime a different date&time in the future like 5 April 2006... Has anyone a idea which patch caused this, or what i can do? |
10-10-2004, 02:13 | #686 (permalink) | |
one is SYSTEM Patch , another is GRAPHIX Patch System Patch like DigiClock in KeyLocked mode , AOAB , SlowLightUp Patch etc. that change some system in phone to new one Graphix Patch is Patch File that need to be used with some System Patch like Digi Clock picture , Numberic picture ect. this patch change some old picture in phone to new one that must to be used with System patch you must install System patch in correct FW that you have (System patch FW10 must install in FW10 except FW11 and FW91 they can installed some same patch) and almost Graprix patch can be installed in any FW (if it is same picture number) and about sequence to install patch is not much important except some patch that they are edited some data in some addreess and for your case you should install as your sequence bcoz in DigiClock in Screensaver patch had change some data in DigiClock in KeyLocked mode as below ;*** M55v10: DiGiTaL CLoCK iN SCReeNSaVeR MoDe *** ;© Matr!x - 29/04/2004 ; ;Patch "DIGICLOCK IN KEYLOCKED MODE" must be installed! ;Change "Menu > Setup > Display > Screensaver > Style > Analog clock" ;do not show digiclock on mainscreen when key locked ;0DC86A: DA5500B4 E6FCB101 0E5A54: 88908880 FA5500B4 ;Digi Clock in keylock Mode ;M55 FW10 0DC86A: E6FCB101 DA5500B4 i hope this may help you anyway and you should read old previous topics in this forum that will help you a lot to understand about install patch anuroj_007:Siemens M55 FW07-->FW10-->FW11-->FW91-->FW10+patches: Last edited by anuroj_007; 10-10-2004 at 02:33. | |
10-10-2004, 02:52 | #687 (permalink) | |
try to set Time zones (9-6-2) it may help you i found this problem when i upgrade to FW11 anuroj_007:Siemens M55 FW07-->FW10-->FW11-->FW91-->FW10+patches: | |
10-10-2004, 08:00 | #688 (permalink) | |
Freak Poster Join Date: Feb 2004 Location: Pancevo, Yugoslavia Age: 40
Member: 55726 Status: Offline Thanks Meter: 1 | Quote:
also try to turn off "budist year" in clock options.... i had a patch that makes this option into something else..... and had the same problems as you have now..... Cheers .... | |
10-10-2004, 12:42 | #689 (permalink) |
Member: 53902 Status: Offline Thanks Meter: 0 | I tried all this before, nothing helps... In my M55 I can't find "budist year", my old C55 had it, but I don't think that the M55 has it. And even if it has, that's no reason to change the time every time I restart it. I will start over again with clear fubu, maybe i missed something before. |
10-10-2004, 16:01 | #690 (permalink) | |
as i sad before, i had the same prob that you have, but i overlooked that budist year was on..... i set the date, time, and when i restart the phone, it goes to Jun 2006..... i just unchecked the option, and restarted the phone, and evrything is OK.... try reflashing your fubu... | |
S55 flash patching(Thread for discussing) | zdob | x4x, x5x Flashpatching | 347 | 12-09-2006 13:47 |
X6x Flash patching(THE Thread for discussing) : | zdob | x6x and x7x Flashpatching | 196 | 09-04-2006 19:12 |
SL55 flash patching (Thread for discussing) | 3aTmr | x4x, x5x Flashpatching | 29 | 03-21-2006 20:40 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
