Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 11-20-2003, 11:41   #1 (permalink)
Member: 41616
how to switch on the vibrator on sl45
hi folks
can anybody tell me how to switch on the vibarator function
Old 11-20-2003, 12:20   #2 (permalink)
3aTmr's Avatar
Member: 26670
Thanks Meter: 5
under Audio/Silent Alert....
Old 11-26-2003, 15:21   #3 (permalink)
Member: 41616
vibration
it is still not working
is any prob wit flash
Old 11-26-2003, 19:54   #4 (permalink)
3aTmr's Avatar
Member: 26670
Thanks Meter: 5
maybe, or maybe your vibra motor is not working...
Old 12-01-2003, 13:09   #5 (permalink)
modrone's Avatar
Member: 34029
I think you have to sell yours and buy another one.
I had the same problem half a year ago!
You can buy my sl45 "i" I'm selling it!
email me!
Old 12-01-2003, 16:37   #6 (permalink)
PYCON's Avatar
Member: 26267
It can be maybe a problem of corrupted firm. Not very probable but possible... Try the patch of vibra icon. Or open your SL45 and check the position of vibra motor and its 2 pins. If your vibra is connected but doen't function, u can buy a new vibra motor, in Italy we can find for 4 or 5 euro.
Old 12-02-2003, 00:37   #7 (permalink)
Member: 41707
PYCON is there a shop in Italy that sells covers for SL45?
Old 12-13-2003, 15:01   #8 (permalink)
Member: 46245
i think perhaps the vibra is good,but the circuit is break,3 months ago,i opened my sl45i to change the orange lamp to white ones(some tiny white leds).when i closed the covers,the vibra motor did not work, so i had to opened it again,i found that the spring in the vibra motor did not contact to the metal toucher in the main board.so i used a wire join them by an iron.
you must make it sure that the spring in the vibra motor contact s to the metal toucher in the main board when you close your covers of sl45i.
Old 12-13-2003, 16:18   #9 (permalink)
trustkill's Avatar
Member: 27745
I had the same problem, too !
samsung c 170 has a 2 different type of PWB, incl the LCD,how to switch the lcd?? mantok Z3X-Team Products 1 01-25-2010 08:06
6131 how to switch on? fingusio BB5BOX 1 10-06-2007 19:11
How to switch clock on Mot2288 ? De Moon Motorola ODM 4 11-14-2003 07:42
How do you remove the casing on an sl45? PixL x1x to x45/x50 0 07-01-2002 19:23
How to take off front cover on SL45 ? ? ? bluelights x1x to x45/x50 2 09-13-2001 19:01
Page generated in 0.17015 seconds with 9 queries
