Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 04-26-2004, 10:26   #46 (permalink)
Member: 63705
Is there a patch, that shows SMS with small chars? (like MMS texts or WAP texts)
Old 04-26-2004, 10:55   #47 (permalink)
Member: 63705
Girosavo!
Your small Fonts patch only work with menu and main screen? Can U make a patch for sms with small text too?
Old 04-26-2004, 15:52   #48 (permalink)
Member: 63705
Is it possible to make a patch for S55 with Drive B like to M55?
Old 04-26-2004, 18:24   #49 (permalink)
Member: 62929
Question
;S55v20 - Provider Name -> Accu in Volts and Percentages, Temperature
;(c) ACiD[mrp], avkiev
; Format: 3,938=75% 25,3'C
; If you already applyed the "Provider to smth" Patches - please undo theirs first
31AAE8: E04E00E066FEFF3FF2FF02FE DA6100A9E6FE2001E6FF0300
21A900: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88608870888088C088D0D7401000F2FC
21A910: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9638F6FC0EFEE6FD64004BDDF2FC0EFE
21A920: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FD0CFEBB5FD7600300F7FE20C1E7FE
21A930: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2C00F7FE21C1F078F7FE22C1F0CDBB52
21A940: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7600300F7FE23C1F078F7FE24C1E7FE
21A950: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D00F7FE25C1D7400F00F2FC2828BB42
21A960: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7700300F7FE26C1F078F7FE27C1E7FE
21A970: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2500F7FE28C1E7FE2000F7FE29C1D740
21A980: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6900F2FCB279E6FDAA0A20CDF6FC0EFE
21A990: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0AD4BDDF2FC0EFEF2FD0CFEBB23D760
21A9A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0300F7FE2AC1F078F7FE2BC1E7FE2C00
21A9B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F7FE2CC1F0CDBB16F078D7700300F7FE
21A9C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2DC1E7FE2700F7FE2EC1E7FE4300F7FE
21A9D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2FC1E10EF7FE30C198D098C098809870
21A9E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9860DB00F6FC0EFEE0A65B66F2F70EFE
21A9F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFF F2F80CFE06F7300006F83000CB00
; Provider Name -> Time, Environment Temperature
; Format: 10:01 - 24,5'C
; S55 v20
; 2004 by ACiD[mrp]
; GSM Development Crew www.gsm-dev.com
; Mobiletuning www.mobiletuning.de
; If you already applyed the ProviderTime Patch please
; undo this first.
; Sorry, there's no ° available so I've used an '
0031AAEC: 66FEFF3F E6FE2001
0031AAF0: F2FF02FE E6FF0300
0031AAE8: E04E00E0 DAFD0C00
BD000C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88608870888088C088D0D7400D00F3FE
BD001C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BE44F0C7BB6ED7400300F7FE20C1F078
BD002C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400300F7FE21C1E7FE3A00D7400300
BD003C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F7FE22C1D7400D00F3FEBC44F0C7BB59
BD004C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400300F7FE23C1F078D7400300F7FE
BD005C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 24C1E7FE2000D7400300F7FE25C1E7FE
BD006C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D00D7400300F7FE26C1E7FE2000D740
BD007C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0300F7FE27C1D7406900F2FCB279E6FD
BD008C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF AA0A20CDF6FC0EFEE0AD4BDDF2FC0EFE
BD009C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FD0CFEBB2ED7400300F7FE28C1F078
BD00AC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400300F7FE29C1E7FE2C00D7400300
BD00BC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F7FE2AC1F0CDBB1DF078D7400300F7FE
BD00CC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2BC1E7FE2700D7400300F7FE2CC1E7FE
BD00DC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 4300D7400300F7FE2DC1E10ED7400300
BD00EC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F7FE2EC198D098C0988098709860BB01
BD00FC: FFFF DB00
BD00FE: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC0EFEE0A65B66F2F70EFEF2F80CFE
BD010E: FFFFFFFFFFFFFFFFFFFF 06F7300006F83000CB00
can someone pls merge these two patches to one showing "time - accu in percentages", e.g. 19:20 - 75% ?
TIA
Old 04-26-2004, 18:28   #50 (permalink)
Member: 62929
; 2004 by ACiD[mrp]
; idea, SL45 version & MIDlet
; by abomin, SiNgle (THX for ideas))
; S55 v20
; www.gsm-dev.com
; this will run an MIDlet on SIM change
; used to send an Security SMS
; till now the question "allow to send SMS" will apear
; I hope someone can find this message. I was not successfull till now
; use this MIDlet:
; ftp://ronees.unets.ru/siemens/SecureSMS.rar
8B2B06: DA927264 E6FC1000 ; mov r12, #10h
8B2B0A: 48403D04 DA730E87 ; calls HideSelectDefaultBook()
8B2B16: DADAC81348403D0A DA6100A8FACB322B ; don't ask to copy bull****
; Send Sercurity SMS
0021A800: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E006D7400D00F7FCD855E6FC1828E6FD
0021A810: FFFFFFFFFFFFFFFF 8601E00EFA97ACAF
; a:\Java\jam\SecureSMS\GSM.jar
; change this to run another MIDlet
0021A818: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 613A5C4A6176615C6A616D5C53656375
0021A828: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 7265534D535C47534D2E6A617200
pls what to change in this script to work with path a:\Java\jam\apps\SecureSMS\GSM.jar ?
Old 04-26-2004, 18:43   #51 (permalink)
Member: 50065
Paste "613A5C4A6176615C6A616D5C536563757265534D535C47534 D2E6A617200" in hex edytor and change.
Old 04-26-2004, 22:12   #52 (permalink)
Member: 63705
can someone make a patch for call filter that to cause a busy sound instead of normal ring?
Old 04-26-2004, 22:18   #53 (permalink)
Member: 50065
Use BlackList - Effect will be same.
Old 04-27-2004, 10:01   #54 (permalink)
Member: 62929
thx for fast reply wlodixon
so, just for sure ... patch will look after change like this:
0021A818: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 613A5C4A6176615C6A616D5C536563757265534D535C47534D 2E6A617200
Old 04-27-2004, 11:53   #55 (permalink)
Member: 63705
Is there a patch that remove "low battery" text?
Old 04-27-2004, 13:09   #56 (permalink)
Member: 50065
Better Try this
; ************ a:\Java\jam\apps\SMS\GSM *****************
0021A818: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 613A5C4A6176615C6A616D5C617070735C
0021A828: FFFFFFFFFFFFFFFFFFFFFFFF 534D535C47534D2E6A617200
No
Old 04-27-2004, 14:58   #57 (permalink)
Member: 62929
@wlodixon mhmm, looks fine, but v_klay is reporting error (attached)
Old 04-27-2004, 15:10   #58 (permalink)
Member: 50065
Upss... Sorry
0021A818: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 613A5C4A6176615C6A616D5C617070735C
Try this
Old 04-27-2004, 16:35   #59 (permalink)
Member: 62929
@wlodixon
well, it's fine, but it doesn't work
you have defined path "a:\Java\jam\apps\SMS\GSM", my path was "a:\Java\jam\apps\SecureSMS\GSM.jar"
i changed it to "a:\Java\jam\apps\SMS\GSM.jar", but it doesn't work also ...
Old 04-27-2004, 17:57   #60 (permalink)
Member: 50065
You must test - I give up
M55 flash patching(Thread for discussing) zdob x4x, x5x Flashpatching 880 01-25-2010 05:37
X6x Flash patching(THE Thread for discussing) : zdob x6x and x7x Flashpatching 196 09-04-2006 19:12
SL55 flash patching (Thread for discussing) 3aTmr x4x, x5x Flashpatching 29 03-21-2006 20:40
S55 flash with wrong flash file. WillGsm E-Gold Based Phones 2 01-29-2005 13:58
Page generated in 0.20475 seconds with 10 queries
