WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
07-25-2003, 23:36 | #1 (permalink) |
Junior Member Join Date: Feb 2001 Location: germany
Member: 3387 Status: Offline Thanks Meter: 0 | 100 % nokia3650 fade off solution fix here is my gift to you.. next week i am in vacation. on my page is the unprotected fia file. lets go . lets start to repair our nokias .. ;o) www.creativelabor.de regards cliff aka bassmc |
07-26-2003, 07:44 | #2 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | thank you brother but how do we use this little file ??? i have griffin and how do i use this file for fixing my 3650.....???? thanks in advance WBR Syed |
07-26-2003, 15:11 | #3 (permalink) | |
No Life Poster Join Date: Apr 2002 Location: Tutuban Age: 68
Member: 10635 Status: Offline Thanks Meter: 10 | Re: 100 % nokia3650 fade off solution fix Quote:
BR, Epic | |
07-26-2003, 17:20 | #6 (permalink) |
Member: 3387 Status: Offline Thanks Meter: 0 | original name ok.. original name (nokia website)of this file is : CSSErasePMM.fia i have no problem. i erase the pmm section and after this work i flash this phone with new firmware.. my tools are fls4-s und orginal cable with nhl-8 flash loading adapter. regards bassmc |
07-26-2003, 17:25 | #7 (permalink) |
Member: 3387 Status: Offline Thanks Meter: 0 | phoenix i have phoenix and all other original software from nokia. i flash with fls4-s. i think there are many difference between orginal nokia phoenix and neelix or griffin. i have this tools at home and all phone works fine. regards bassmc |
07-26-2003, 17:52 | #8 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Philippines Age: 54
Member: 22588 Status: Offline Thanks Meter: 29 | You can also try this, but definitely will lose signal (simlock data..etc is intact) 1. Flash your 3650 with a 7650 flash file. it will somehow affect the PMM area thereby removing fading (and signal ofcourse). 2. Now, when error occurs during flashing, just repeat the procedure but this time use a 3650 flashfile. Check manual mode when using griffin....if you have an original nokia equipment, then your lucky...just repair the PMM area to regain the signal back..... |
07-26-2003, 18:01 | #9 (permalink) |
Member: 19979 Status: Offline Thanks Meter: 116 | well that means for Griffin or Neelix no sure solution yet for the problem...and what good is the solution if fading goes and so does the signal ??..the phone is anyway still useless.... WBR Syed |
07-29-2003, 07:59 | #10 (permalink) |
No Life Poster Join Date: Dec 2001 Location: mumbai Age: 54
Member: 7889 Status: Offline Thanks Meter: 7 | this file you can use with griffin also tested as i tried on one unit which authorised nokia service senter returned saying its a hardware now i renamed this file to nhl3025.090 and flashed only selecting ppm phone is back to life its now no fading off showing insert sim also reflashed original mcu ppm after flash processing and all ok now with griffin but...the big but..........it is stiil use less cant upload sp data with griffin and its a simcard rejected with sim oh......... now waithing for some mirecal |
07-29-2003, 08:08 | #11 (permalink) | |
Member: 7889 Status: Offline Thanks Meter: 7 | Quote:
so it cant be repair with griffin will pkd 1 and f bus cable wiil do ?? thanks | |
08-02-2003, 02:03 | #12 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Never Land
Member: 7277 Status: Offline Sonork: 100.42158 Thanks Meter: 68 | i think right now no one wants to give solution to that kind of problem... but try to read this....maybe this could help. Nokia Mobile Phones Service Bulletin No. SB-012/24.06.03 Technical Services, Europe & Africa NHL-8 CORRUPTED PERMANENT MEMORY MANAGER (PMM) Recognizing the PMM corruption symptom: With a battery inserted, try to switch the phone on. The display backlight will come on for the usual time (around 3 seconds) and the NOKIA logo will be seen for a very short time (much less than 1 second) before the display fades or switches off. This repeats a few times and the phone shuts-off completely. The phone will also not boot in Local mode (connected to a flash adapter) with similar symptom – NOKIA logo shown for less than 1 second. This problem is caused by a corruption to the Permanent Memory, which prevents the phone from booting. Since the phone will not boot, it is not possible to backup any settings from the phone. If the above-mentioned symptoms are detected in level 1 & 2 service points, the phone should be sent for repair to higher level service partner. IMPORTANT: If the NOKIA logo remains on the screen for longer than 1 second, the phone does not suffer from this problem. See section ‘other software based issues’. Steps to repair PMM corruption: Note: User Data will not be affected, but other tuning and alignment data will be lost – including PPCs. 1.Re-flash the phone with the latest available NHL-8 software. 2.Flash the single flash file CCSErasePMM.fia (available on PWS) to the phone by selecting it in the MCU section of the Flash window in Phoenix. 3.The IMEI/SIM lock must then be rebuilt and the phone re-aligned and re-calibrated. Other software based issues: When the phone is switched on with a battery inserted, a check is executed on the program code. When the NOKIA logo is displayed, this check has passed. (I.e. if the check fails, the logo is not displayed.) Therefore, if the NOKIA logo is seen, even for the briefest time, the problem is not with the program code, and re-flashing may not help. A common cause of failures to boot is bad applications installed by the end user. If the phone boots and is stable in Local mode (on a flash adapter or docking station), but does not with a battery inserted, the problem is probably with the User Data Area. In these cases, try formatting the user data area. Remember – User data will be lost! Best regards, |
08-02-2003, 06:22 | #13 (permalink) | |
for step three will normal fbus cable and pkd wiil do? or i need any spacial instrument | |
w300 keypad on off 100 % working | pp_metal | Sony Ericsson Hardware Repair | 0 | 07-05-2008 00:40 |
Solution A35 Wrong Software 100 % working | DeJe | x1x to x45/x50 | 10 | 05-07-2002 16:25 |
SONY CMD J5 Full Solutions 100 % working FREE | fungsm | Sony | 4 | 09-08-2001 18:48 |
