WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
06-10-2004, 21:33 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Age: 39
Member: 44610 Status: Offline Thanks Meter: 50 | 6600 Big Problem!! I got here a 6600 that says Simcard registeration failed. Wheni insert simcard all works perfect but after 2-3 hours it says simcard registeration failed but Sim is good.. I've flashed fone but no help... have any one noticed this prob?? BR Didi |
06-10-2004, 22:02 | #3 (permalink) |
Member: 44610 Status: Offline Thanks Meter: 50 | Not @ all. Can 8 Sims be Bad @ one?? Nooooo... This thing looks surprising.. though it works sometimes about 4 - 5 hours perfecly, recieve and make calls next thing Sim Registeration Failed... More comments and advice welcomed here... Br Didi |
06-11-2004, 14:37 | #6 (permalink) | |
No Life Poster Join Date: Jul 2002 Location: uk
Member: 13808 Status: Offline Thanks Meter: 163 | Quote:
remember doing factory reset on a fully functional phone could give you contact retailer, but choose the UIn setting of FUKK FACTORY SETTING to be done automatically fafter flashing. and use the lastest flash file.. b\R | |
06-11-2004, 18:51 | #7 (permalink) |
Junior Member Join Date: Oct 2002 Age: 48
Member: 16328 Status: Offline Thanks Meter: 0 | Check your phone software version. If its 4.09 you should downgrade to 3.42. This is one of the bugs on version 4.09. Strange is'nt it? Check it and you will see. BR Edwwinnc |
06-11-2004, 21:39 | #8 (permalink) | |
Member: 44610 Status: Offline Thanks Meter: 50 | Quote:
I very sure phone is not barred cuz i even copied imei and put on DTC3 to confirm. I used phone (DTC3) with the same imei on 6600 for a day no prob at all phone works perfectly and make and recieve calls. Although it was a lower version before with the same prob but after flashing it with a higher version the prob still remains although i will still try the same again including FORMAT USER AREA and post result.. BR Didi | |
06-12-2004, 12:48 | #10 (permalink) | |
Freak Poster Join Date: Jun 2004 Location: KL Malaysia Age: 48
Member: 68635 Status: Offline Thanks Meter: 0 | Quote:
i have this problem b4 it sotf by change the simcard i/c | |
06-12-2004, 12:50 | #11 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | U are wellcome to a world of Unbelievables Quote:
Prodigy, Griffin & Twister ? U think we like wasting money ? No Way. There is a Nigerian "pidgin" saying that goes this way "If U sabi this 1, U sabi that 1 ???" If U look around, U will see many 'pro' members some even have Twister and UFS2. Thet are not fools. Go ahead and flash with twister, and tell me how the customer collected back the phone undone. | |
06-12-2004, 13:29 | #12 (permalink) | |
Keep chasing me Thread to thread, post 2 post..... U said some of us having Twister, prodigy (Ur rusted one??), Griffin... I have flashed this fone with 2 diff flashers bu prob still remain.. Br Didi | |
06-12-2004, 13:31 | #13 (permalink) | |
Tanks Br Didi | |
06-12-2004, 13:47 | #14 (permalink) | |
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | I cant see that anywhere Quote:
Post to post, thread to thread ??? I dont get you, OK, I stop helping or suggesting to you ?? If U want, I agree, no problem. U said you flashed phone with 2 flashers ????/ Which is second flasher ???? BCOS U NEVER MENTIONED THIS EARLIER, unless U want to edit your post, then we know. Flasher is different from flash files, I KNOW U KNOW | |
6600 big problem | jln310 | WD2 & APE (Symbian Phones) | 3 | 10-06-2004 06:54 |
Nokia 6600 BIG PROBLEM!!! | COBRAlethal | WD2 & APE (Symbian Phones) | 0 | 08-09-2004 12:24 |
Nokia 6600 BIG PROBLEM | BadHabbit | WD2 & APE (Symbian Phones) | 3 | 08-07-2004 13:58 |
6600 big problem | gsm_style | Nokia Hardware & Hardware Repair | 4 | 07-30-2004 20:10 |
6600 big problem | OMBOSSMAN | UFS2 + UFS3-Tornadoflasher | 6 | 02-17-2004 19:48 |
