WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
07-17-2004, 14:35 | #1 (permalink) |
No Life Poster Join Date: May 2004
Member: 64957 Status: Offline Thanks Meter: 100 | 6600 dead dont worry.look here. u need 1 griffin 2.085 2 flash_update_03_09 3 6600 full erase file 4 full flash pack NHL-10_dp_EUR_v_3_0_MCUSW4_09_1 5 anoter full flash NHL103480 run flash update 03.09. run NHL-10_dp_EUR_v_3_0_MCUSW4_09_1. extract flash 3.4.8 to Nhl-10 ready to flash open griffin tick manual mode 1.open ppm load 6600 full erase file press flash,dont tick the "full factory setting after flash" 2.open ppm load c4 flash,press flash. now untick manual mode,tick the "full factory setting after flash" open mcu load c1 flash,chose desired ppm. flash.some time it stop in middle dont worry just change the ppm alone and flash thats all. after flash format user area unlock write ppm. thats it.hope this works.it worked for me. Griffin the great. BOL. Last edited by raffazila; 07-19-2004 at 11:19. |
07-20-2004, 04:29 | #4 (permalink) |
Junior Member Join Date: Jul 2004 Age: 40
Member: 73828 Status: Offline Thanks Meter: 0 | Hello!!!!!!! i have 6600 which i bought 2 months ago Can you pls tell me what is flashing (i m not too sure .... i think its something related to formatting ) and when i flash ... will i loose my Nokia s/w too and if so then from where can i get it also i want to know is from where can i get the registeration codes for the try and buy softwares Thanks in advance , Digital_Freak |
07-20-2004, 10:43 | #5 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | @ Digital Freak Flashing a phone is when you connect it do a pc via a flash interface like Griffin, UFS-3 , Prodigy ,Matrix or Neelix when flashing first it erases your memory so you wll loose the "Noki s/w on your phone Flashing a phone replaces the current software version with whatever you flash it with. You normally flash phones when they have software bugs or the software crashes ie dead phone I suggest buying flashing hardware/software or paying a cellular repair centre to do this for you Regards D. |
07-20-2004, 20:08 | #6 (permalink) |
Member: 73828 Status: Offline Thanks Meter: 0 | @ DMD Thanks Man For the information i really appreiciate it ... can you pls tell me where can i get the cracks or the registration codes for the "TRY AND BUY" softwares i searched aivanet.com but no results any suggestions....... thanks in advacnce |
help me in 6600 erase and flash procedure. | zone2 | Nokia Hardware & Hardware Repair | 2 | 11-29-2007 04:25 |
need samsung x600 flash procedure with flash file | manish665 | HWK | 5 | 10-24-2007 07:37 |
6600 flashing error now 6600 dead | kabeermaster25 | Nokia Hardware & Hardware Repair | 25 | 04-08-2006 02:31 |
E398 Flash Files and Flashing Procedure ? | Sir_GsM | Smart-Clip | 4 | 04-14-2005 10:44 |
VictorGSM 3.2.3 cracked flash procedure... | jaleo | Motorola P2k | 12 | 05-23-2003 13:42 |
