WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
10-19-2005, 23:47 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: gold land Age: 46
Member: 16904 Status: Offline Thanks Meter: 9 | 6600 local mode and test mode failure i have much of case 6600 reflashing ok! but after reflashing not showing nokia logo on the screen when try normal mode,lokal mode,or test mode my ufs said fail. for example i have 6600 changed 4pcs flash ic, and reflashing phone but still cant switch on the phone regards |
10-22-2005, 06:15 | #3 (permalink) |
Major Poster Join Date: Jul 2005 Age: 38
Member: 157786 Status: Offline Thanks Meter: 7 | 6600 local mode and test mode failure MY NOKIA 6600 FLASHUNG IS OK BUT NOT POWER ON WHEN I ON IT ITS SHOW ONLY WHITE DISPLAY AFTER SAME SECOND IT OFF.PLZ HELP ME........ TAHNK YOU |
10-25-2005, 16:14 | #5 (permalink) |
Insane Poster Join Date: May 2002 Location: INDIA-KARNATAKA Age: 48
Member: 12302 Status: Offline Thanks Meter: 22 | If you are using UFS(N-BOX,POWER FLASHER,GRIFFIN,JAF) BOX must erase flash through erase file (File names is 6600 full erase.fia). Erasing procedure. paste 6600 full erase.fia to c:/programm files/nokia/phoenix/products/nhl-10 execute DCTx software --- remove use ini file settings--select flash only ppm--- choose (file type *.*)6600 full erase.fia -- flash. erase 5 times then you must choose mcu and ppm file. After coming in local mode write pm , init simlocks and format user area. |
10-02-2007, 07:24 | #7 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | Quote:
bro, try to replace this may helpful to u | |
The Following User Says Thank You to jimm07ct For This Useful Post: |
1661 local mode and test mode solution here | Y2ksalman | Nokia Hardware & Hardware Repair | 21 | 06-08-2012 11:44 |
nokia 1661 local mode and test mode solved | venusmobilecare | Nokia Hardware & Hardware Repair | 25 | 07-13-2011 16:30 |
Nokia 6070 local mode and test mode help me | ansari123 | Nokia Hardware & Hardware Repair | 5 | 07-05-2009 16:11 |
plaise plaise e65 local mode and test mode | raoul plus | Nokia Base Band 5 ( BB-5 ) | 1 | 02-06-2009 02:32 |
3100 And 3120 Local Mode And Test Mode | Nasmi | UFS2 + UFS3-Tornadoflasher | 0 | 08-30-2005 14:56 |
