Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 07-25-2003, 23:36   #1 (permalink)
Member: 3387
Smile 100 % nokia3650 fade off solution fix
hi friends.. bass is in the house !!!
here is my gift to you.. next week i am in vacation.
on my page is the unprotected fia file. lets go . lets start to repair our nokias .. ;o)
www.creativelabor.de
regards cliff aka bassmc
Old 07-26-2003, 07:44   #2 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 116
thank you brother but how do we use this little file ???
i have griffin and how do i use this file for fixing my 3650.....????
thanks in advance
WBR
Syed
Old 07-26-2003, 15:11   #3 (permalink)
epic's Avatar
Member: 10635
Thanks Meter: 10
Re: 100 % nokia3650 fade off solution fix
Yes, this fix the problem of fading but at the same time it also erases all simlock data and loses signal of the phone....so you will need Special equipment now in restoring this data to the phone...
BR,
Epic
Old 07-26-2003, 15:49   #4 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 116
but still how do u use this file ?????
Old 07-26-2003, 16:58   #5 (permalink)
mobilemafia's Avatar
Member: 7889
Thanks Meter: 7
YES IT ERASES SIMLOCK DATA
TRIED WITH GRIFFIN
PHONE IS BACK TO LIFE BUT SIM CARD REJECTED AND ALSO
NO NETWORK
JUST RENAME IT TO PPM LIKE
Old 07-26-2003, 17:20   #6 (permalink)
Member: 3387
original name
ok.. original name (nokia website)of this file is : CSSErasePMM.fia
i have no problem. i erase the pmm section and after this work i flash this phone with new firmware.. my tools are fls4-s und orginal cable with nhl-8 flash loading adapter.
regards bassmc
Old 07-26-2003, 17:25   #7 (permalink)
Member: 3387
phoenix
i have phoenix and all other original software from nokia.
i flash with fls4-s. i think there are many difference between orginal nokia phoenix and neelix or griffin. i have this tools at home and all phone works fine.
regards bassmc
Old 07-26-2003, 17:52   #8 (permalink)
Member: 22588
Thanks Meter: 29
You can also try this, but definitely will lose signal (simlock data..etc is intact)
1. Flash your 3650 with a 7650 flash file. it will somehow affect the PMM area thereby removing fading (and signal ofcourse).
2. Now, when error occurs during flashing, just repeat the procedure but this time use a 3650 flashfile.
Check manual mode when using griffin....if you have an original nokia equipment, then your lucky...just repair the PMM area to regain the signal back.....
Old 07-26-2003, 18:01   #9 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 116
well that means for Griffin or Neelix no sure solution yet for the problem...and what good is the solution if fading goes and so does the signal ??..the phone is anyway still useless....
WBR
Syed
Old 07-29-2003, 07:59   #10 (permalink)
Member: 7889
Thanks Meter: 7
this file you can use with griffin also tested
as i tried on one unit which authorised nokia service senter returned saying its a hardware
now i renamed this file to nhl3025.090
and flashed only selecting ppm
phone is back to life
its now no fading off
showing insert sim
also reflashed original mcu ppm
after flash processing and all ok now with griffin
but...the big but..........it is stiil use less
cant upload sp data with griffin and its a simcard rejected with sim oh.........
now waithing for some mirecal
Old 07-29-2003, 08:08   #11 (permalink)
Member: 7889
Thanks Meter: 7
so it cant be repair with griffin
will pkd 1 and f bus cable wiil do ??
thanks
Old 08-02-2003, 02:03   #12 (permalink)
Member: 7277
Sonork: 100.42158
Thanks Meter: 68
i think right now no one wants to give solution to that kind of problem...
but try to read this....maybe this could help.
Nokia Mobile Phones Service Bulletin No. SB-012/24.06.03
Technical Services, Europe & Africa
NHL-8
CORRUPTED PERMANENT MEMORY MANAGER (PMM)
Recognizing the PMM corruption symptom:
With a battery inserted, try to switch the phone on. The
display backlight will come on for the usual time (around
3 seconds) and the NOKIA logo will be seen for a very
short time (much less than 1 second) before the display
fades or switches off. This repeats a few times and the
phone shuts-off completely.
The phone will also not boot in Local mode (connected to
a flash adapter) with similar symptom – NOKIA logo shown
for less than 1 second.
This problem is caused by a corruption to the Permanent
Memory, which prevents the phone from booting. Since
the phone will not boot, it is not possible to backup any
settings from the phone.
If the above-mentioned symptoms are detected in level
1 & 2 service points, the phone should be sent for repair
to higher level service partner.
IMPORTANT: If the NOKIA logo remains on the screen for
longer than 1 second, the phone does not suffer from
this problem. See section ‘other software based issues’.
Steps to repair PMM corruption:
Note: User Data will not be affected, but other tuning
and alignment data will be lost – including PPCs.
1.Re-flash the phone with the latest available NHL-8
software.
2.Flash the single flash file CCSErasePMM.fia (available
on PWS) to the phone by selecting it in the MCU section
of the Flash window in Phoenix.
3.The IMEI/SIM lock must then be rebuilt and the phone
re-aligned and re-calibrated.
Other software based issues:
When the phone is switched on with a battery inserted,
a check is executed on the program code. When the
NOKIA logo is displayed, this check has passed. (I.e. if
the check fails, the logo is not displayed.) Therefore, if
the NOKIA logo is seen, even for the briefest time, the
problem is not with the program code, and re-flashing
may not help.
A common cause of failures to boot is bad applications
installed by the end user. If the phone boots and is
stable in Local mode (on a flash adapter or docking
station), but does not with a battery inserted, the
problem is probably with the User Data Area. In these
cases, try formatting the user data area. Remember –
User data will be lost!
Best regards,
Old 08-02-2003, 06:22   #13 (permalink)
Member: 7889
Thanks Meter: 7
Best regards,
thanks for information but
for step three will normal fbus cable and pkd wiil do?
or i need any spacial instrument
Old 08-04-2003, 15:14   #14 (permalink)
Member: 7277
Sonork: 100.42158
Thanks Meter: 68
pkd1,fls4s and fps8
Old 08-04-2003, 17:18   #15 (permalink)
Member: 10243
Thanks Meter: 18
what about PRODIGY?
w300 keypad on off 100 % working pp_metal Sony Ericsson Hardware Repair 0 07-05-2008 00:40
Solution A35 Wrong Software 100 % working DeJe x1x to x45/x50 10 05-07-2002 16:25
SONY CMD J5 Full Solutions 100 % working FREE fungsm Sony 4 09-08-2001 18:48
Page generated in 0.21192 seconds with 10 queries
