WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
03-13-2004, 00:05 | #1 (permalink) |
Freak Poster Join Date: Aug 2001 Location: on air Age: 46
Member: 5921 Status: Offline Thanks Meter: 5 | 7650 signal problem need HELP it also have a little power consumption. can somebody help me coz i don't know what to do...? thank you! |
03-31-2004, 17:50 | #4 (permalink) |
Product Supporter Join Date: Oct 2002 Location: Philippines/Shenzhen, China Age: 58
Member: 16816 Status: Offline Sonork: 100.42691 Thanks Meter: 105 | much better dont touch first mention parts and try replacing UEM first. its the usually first to conked out |
05-04-2004, 02:35 | #8 (permalink) | |
Insane Poster Join Date: Apr 2004
Member: 62999 Status: Offline Thanks Meter: 0 | Quote:
I/Q & power level values. If U change sumthing in the RF part, U must keep this values finetuned 4 ideal reception. Not easy...And U can't get this stuff in the next drogery... BR.:ESP | |
05-10-2004, 01:19 | #10 (permalink) | |
In another words: after U changed anything (power amplifier, diplexer, etc...) in the radio part of Ur fone, U must re-calibrate all the radio settings (transmit power level values, phase shifting, modulation, etc...) for a good signal reception. If U don't, maybe Ur fone looks like found network, but if anyone calls U he / she gets a busy signal or "not reachable"...I hope it was clear now... BR.:ESP | |
05-10-2004, 22:52 | #11 (permalink) |
Member: 5921 Status: Offline Thanks Meter: 5 | man... my 7650 has no signal. NO SIGNAL!!! it's not about good signal reception. the problem is sofware... before flashing full signal, good reception etc, but after flash no signal at all. PMM doesn't help. any idea??? |
05-11-2004, 22:13 | #12 (permalink) | |
Ok, I got it...In 7650 series is a common fault the untuned radio part after flashing, especially U flash it with Phoenix, but maybe Griffin or Prodigy can cause it too.If problem is not solved with flashing many times (sometimes 6-7 or more cycling complete flash update required to normal operation), U must change the UEM or HAGAR to success...And this operation needs recalibrating the RF part... BR.:ESP | |
05-13-2004, 01:49 | #14 (permalink) | |
Try to change back those spareparts what U've changed, and after that try 2 flash it several times in cycle till U get a working phone again. If U tried more than 10 flashes and did'nt work, U have 2 change the UEM (Bcoz it's faulty) and recalibrate the radio data values (it's necessary after changing UEM). Unfortunately U can't do sidestep in this case...If U're a lucky guy, U must do only the flashing... My crossed fingers 4 U,m8... )) BR.:ESP Last edited by ESProc2k; 05-13-2004 at 02:16. | |
05-13-2004, 02:33 | #15 (permalink) |
Member: 5921 Status: Offline Thanks Meter: 5 | thank you for concerning about my problem... the only thing i've changed in this phone was antena switch and pfo, but these spear parts was changed after i've flashed phone with griffin more than 10 times i guess. soo... you say that in this case the only thing that can help me is changing uem and recalibrating? and if it still don't work? at least i tried? in this case i have to pay to griffin team for rpl. i don't like the ideea to pay because the only way i can do it is by western-union and i hate this. |
LG KU990 weak signal problem, need help pls!!! | gr8_viruz | LG Hardware Repair | 5 | 05-07-2009 12:28 |
lg u8110 low signal problem need help | Raja Ramiz | SETool2 | 2 | 09-15-2008 12:54 |
6230 Signal problem need Help Plzzzzzzz | Aazib jhon | Nokia Hardware & Hardware Repair | 5 | 12-29-2007 04:27 |
7650 signal problem | razvan | Nokia Hardware & Hardware Repair | 0 | 03-12-2004 00:56 |
7650 signal problems | welly2000 | WD2 & APE (Symbian Phones) | 4 | 06-26-2003 11:39 |
