WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
02-19-2008, 08:04 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: jb cell world Age: 47
Member: 70916 Status: Offline Thanks Meter: 56 | Phone Start-up Failed - PHONE IS NOKIA 7610 7610 no water damage board is cleane it says phone startup failed.contact the retailer. i flashed with latest ver v7.06 & format user area done uisettings but problem is same pls can any one giv e me working solution |
The Following 3 Users Say Thank You to jbbasha For This Useful Post: |
02-19-2008, 21:59 | #6 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Seraat-e-Mustaqeem Age: 38
Member: 228476 Status: Offline Sonork: 100.1575078 Thanks Meter: 114 | Dear, I've solved this problm many times by using chainees verison have u tried chainess version? ur phone will b fine. after flash complete, click on Format User Area then on the top, right side of UI Setting select Normat Mode fon will say Insert Sim reply Best of Luck Adil |
02-20-2008, 10:35 | #8 (permalink) |
Crazy Poster Join Date: Jun 2007 Location: Baguio City Philippines Age: 42
Member: 531261 Status: Offline Thanks Meter: 36 | did you check the imei...is it not ?????????....try manual formatting.....press *,3,call then power on at the same time within 5 sec...works for me.. |
02-20-2008, 17:46 | #9 (permalink) |
No Life Poster Join Date: Feb 2008 Location: INDIA
Member: 697664 Status: Offline Sonork: 100.1602716 Thanks Meter: 267 | man 1st check ,can it take ui setting or full factory setting if not then replace uem for imei question mark,then write rpl , bro san9090 |
02-20-2008, 19:28 | #10 (permalink) |
Junior Member Join Date: Feb 2008 Location: dubai Age: 38
Member: 711832 Status: Offline Thanks Meter: 2 | Hi all take my salam.i am a new user.'yesterday i was soft this same problem with 6021.u can use ufshwk pm edit oftion after read pm then fixed item then flash pm after fullfactory defaults. susccesful here. |
02-20-2008, 20:48 | #11 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | dear brother. in ufs do flash & then click "FORMAT USER AREA" then UI settings . work fine. same problem i solve 3 times. Khadim Hussain Raabta Mobiles |
02-20-2008, 20:59 | #12 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Always Here Age: 37
Member: 333494 Status: Offline Sonork: 100.1607053 Thanks Meter: 190 | If you make UI settings in WD2 after this your phone write startup faield. in WD2 you don`t need make UI Settings! only FORMAT USER AREA and your problem will be soloved |
02-25-2008, 03:17 | #13 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 562532 Status: Offline Thanks Meter: 10 | yes i agree with sema2283..after formating user area dont check all ui settings..jst click on the full factory defaults..write good pm den initsimlocks..coz if agen if ull check all ui settings same thing will happen, contact retailer. |
Phone Start-up Failed - PHONE IS NOKIA 6630 | nshkw | Nokia Base Band 5 ( BB-5 ) | 25 | 01-01-2009 17:23 |
phone start- up failed nokia 7610 | hjasvy | J.A.F. By Jafsupport.com | 3 | 07-18-2008 12:19 |
nokia 7610 steel phone start-up failed | mouradb3 | Nokia Hardware & Hardware Repair | 16 | 04-28-2008 16:09 |
Nokia 7610 Phone start up failed | mobilecitycbk | Nokia Hardware & Hardware Repair | 8 | 04-27-2008 12:43 |
