I need help with Nokia 3650 Hi I have 2 pcs Nokia 3650 with the same problem , i can't finish the flash ………..first time I connect the phone it was in local mode but after that I can't get local mode at all …. By the way the cable is modified with 3.3 resistance and the phone hardware is working 100% I am using Griffin V2.85 I tried NHL83031.6C1 NHL83025.0C1 NHL83045.7C1 and this is the error V2.52 BoxID:FF8A SN: XXXXXXXX ACTIVATED BOX using autopower Initializing Phone... Boot and Flash loaders operation took 15.078001 seconds Erasing - erase took 184.406009 seconds Flashing MCU - flashing took 385.953018 seconds Erasing - erase took 12.735001 seconds Flashing PPM - flashing took 18.985001 seconds Flashing DONE After flash processing... Trying autopower Fail USER ACTION Griffin failed to communicate with the phone and phone did't power ! Power on the phone and press yes to continue , no to abort phone mode change , YES , NO :mad: Please Help Thank you |
Hi fried!Try this: You can try this solution: 1. flash with 3650 erase files use as ppm (3650_erase_flash0_flash1_flash2.fia 3650_erase_LFFS.fia) 2. flash again with higher/lower than current. (uncheck full factory reset) 3. format user area, if FAIL try again must OK 4. done Work for me!!!! REGARDZ |
.......and try with ver 4.13 REGARDZ |
:) Thanks for your super quick reply .. i will try what you said now |
I forgot to tell U to modify the cable!!!!!!!!!!!!!!!!!!!!!!! U must solder one resistor 3.3k parallel on the one who is inside the cable(black box) |
Problem solved Thank you my friend , it is working . the most important point that we have to uncheck " full factory reset " option . by the way the cable was modified as i said in the Beginning . |
No problem man:) I'm glad to be useful!!! BEST REGARDZ |
