WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
07-13-2004, 11:55 | #1 (permalink) |
Junior Member Join Date: Sep 2003 Location: UAE Age: 49
Member: 38789 Status: Offline Thanks Meter: 0 | I need help with Nokia 3650 I have 2 pcs Nokia 3650 with the same problem , i can't finish the flash ………..first time I connect the phone it was in local mode but after that I can't get local mode at all …. By the way the cable is modified with 3.3 resistance and the phone hardware is working 100% I am using Griffin V2.85 I tried NHL83031.6C1 NHL83025.0C1 NHL83045.7C1 and this is the error V2.52 BoxID:FF8A SN: XXXXXXXX ACTIVATED BOX using autopower Initializing Phone... Boot and Flash loaders operation took 15.078001 seconds Erasing - erase took 184.406009 seconds Flashing MCU - flashing took 385.953018 seconds Erasing - erase took 12.735001 seconds Flashing PPM - flashing took 18.985001 seconds Flashing DONE After flash processing... Trying autopower Fail USER ACTION Griffin failed to communicate with the phone and phone did't power ! Power on the phone and press yes to continue , no to abort phone mode change , YES , NO Please Help Thank you |
07-13-2004, 11:59 | #2 (permalink) |
Freak Poster Join Date: Jul 2004 Location: 0xDEADBEEF Age: 42
Member: 71246 Status: Offline Thanks Meter: 40 | Hi fried!Try this: You can try this solution: 1. flash with 3650 erase files use as ppm (3650_erase_flash0_flash1_flash2.fia 3650_erase_LFFS.fia) 2. flash again with higher/lower than current. (uncheck full factory reset) 3. format user area, if FAIL try again must OK 4. done Work for me!!!! REGARDZ |
07-13-2004, 12:20 | #5 (permalink) |
Member: 71246 Status: Offline Thanks Meter: 40 | I forgot to tell U to modify the cable!!!!!!!!!!!!!!!!!!!!!!! U must solder one resistor 3.3k parallel on the one who is inside the cable(black box) |
07-13-2004, 12:58 | #6 (permalink) |
Member: 38789 Status: Offline Thanks Meter: 0 | Problem solved Thank you my friend , it is working . the most important point that we have to uncheck " full factory reset " option . by the way the cable was modified as i said in the Beginning . |
Need help with HTC 3650. Please..!!!!! | xempt | HTC & Smartphones ( WM Without Touch) | 0 | 01-20-2009 17:24 |
need help with nokia 6131 firmware help!plz | fishcrap | Nokia Base Band 5 ( BB-5 ) | 0 | 09-17-2006 12:53 |
Need Help With Nokia 6385 | INTELLER2 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 01-19-2004 01:51 |
need help with Nokia tools | weiss77 | Nokia Multimedia | 0 | 02-19-2003 13:55 |
Need Help with Nokia 6210 v5.02 | DreamSpell | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-19-2001 23:28 |
