WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
06-13-2004, 17:34 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Earth Age: 38
Member: 32179 Status: Offline Thanks Meter: 5 | No More Side Talking!!!!! Because although there are some people out there who like to Side Talk, most people think it is really silly, really stupid, and something that Nokia should have sorted out straight away. How Do You Do it? Ah, the meat of the article. Right then, grab your N-Gage and pop the back off it. You need to find the telephone speaker housing, which is located on the opposite side of the N-Gage to the MMC Card space. It's a circular indentation just below the main speaker holes. Take a 3mm drill bit and very carefully work through this plastic until you break through the plastic. The speaker is directly under here, so if you drill too hard or too deep, you're going to break the speaker and it's good bye to any sort of talking, side or otherwise. Now take your back casing, and drill the same 3mm hole so it is directly above the 3mm hole in the black back plastic. Some careful measuring should make sure this is in the right place. If you miss, it's okay to make this hole slightly bigger, but not too much. If in doubt the old rule of "measure twice, cut once" should be applied. Using Rear Talkin' So what's it like in use? Exactly as advertised. As long as you didn't damage the speaker when drilling, the sound should be a similar level to side talkin. If you want, you can cover the side talking speaker with your thumb when talking. You could cover it up completely, but you might want to keep the option of side talking available – possibly as a party piece. Dangers? The obvious danger is breaking the speaker when you do the work. But if anything else happens to your N-Gage, the chances of it getting repaired under warranty are pretty much zero, There's also the possibly major matter of electro-magnetic emissions. You are breaking the case of the N-Gage, and also holding it against your head in different manner to that intended by Nokia, and as such the SAR rating of the phone will probably rise due to the different positioning of the phone's antenna in relation to your face. |
06-13-2004, 17:53 | #4 (permalink) |
Member: 32179 Status: Offline Thanks Meter: 5 | By the way guys, if anyone else wants to separate the speaker from the phone before drilling, you need a T6 torx screwdriver to unscrew the screws Its the safer way |
No sound nor talk in handheld. | Waleco | BlackBerry (RIM) | 1 | 04-03-2009 05:12 |
PKEY repair software (no more "PKEY init failed", no more PKEY replacement) | zulea | Main Sales Section | 0 | 03-21-2009 21:48 |
Z558i no power but it can be flashed only have no more free credits!!! | dmaetrey | WotanServer | 1 | 01-12-2008 11:24 |
Thanks to all who sent me d520 dump! It's no more actual. Please, don't send me more. | SFlood | Motorola Old Legacy (EMMI) | 0 | 09-27-1999 15:55 |
