nokia 3650 Memory card password when i try to reach my 3650 memory card in menu option its asking about pasword.? how to remove that ..? Thanks n Regards |
Select the memorycard-icon on your phone. It will then display cardname, capacity and so on. push "select"-button and select password. From here you can enter password. Use blank for no password. |
Hey format your MMC card in 9210 instead of 3650. It will lost all the data. Try and post the results. I've got this solution for password locked memory cards. Cheers! |
for this tim no format the mmc must aske the pass so no way for this time |
i also had this problem....but simply restarting the phone helped me..... WBR Syed |
i have 3650 with memory card locked how to format ? |
i bought my 3650 3 mos ago and it went memory full. It hanged and i brought it for repair in nokia-care. (They say that 3 flash ICs are damaged) After paying Php3000 (USD54), it was ok again. But the problem now is that my MMC is locked for some reasons. I am sure that i did not put any passcode on it when my 3650 is still ok. Is my MMC damaged? Can i still use it? MMC readers cannot eventually read it. Will formatting it in other device (say N9210) can do any good? HELP!! |
untill now the security of memory card - didn't solve SO you just wait a little may be ... :) |
Any Solution for memory Card locked Still no Satisfying result in this thread ??? |
use '' infinity usb phoenix '' device to read ,erase sec-codes. ordinary MMC reader writer device doesnot formate,unlock,even read locked mmc. |
use 9210i and format memory card no your memory card and after you see ok or cancel now chaneg memory card ant got on your memory card and ok format this is bthe best Solution really . |
use 9210i and format memory card no your memory card and after you see ok or cancel now chaneg memory card and got on your memory card and ok format this is the best Solution really . |
use JAF and MMC CABLE and jast make format mmc, will be done!!! |
No is in the software ver . there puting in the phone basically . Because I already encountered that problem . Probably the ver of your fone and the ver. of the software there putting in your fone are different . jjthats why your having . memory password lock. thry to flash your fone with lower the ver. im sure it will work out just fine.:) :) :) |
